Question about Troy Bilt Tb70ss Gas Trimmer
Troy Bilt 4-cycle trimmer won't stop!
Trimmer starts easily and runs fine, but when I press the momentary off switch it won't stop running. I have to pull the spark plug wire to shut it off. Have replaced the momentary switch but no fix.
  • Anonymous Apr 09, 2009
    wont stop when you push the off switch
  • 284 Answers
Take the switch so it is accessable
take the two wires and touch them together or hook them together bypassing the switch
does it shut off or it should not have spark?
if so you have a bad grounding problem if it does not shut off,if it does your switch is still bad
2 wires one tied to ign. module and other to a metal ground all the switch does is dead short. the igniton to shut down the spark and in turn kills the engine.
Be sure your grounding is tight and clean and all wires are intact and making good contact to their designated areas (no broken wires)
hope this helps some for you
Posted on Jun 13, 2009
    Scholar:
  • 76 Answers
Check all wire connections,where they connect to the switch- to the motor-and to each other sounds like a bad ground
Posted on Jan 03, 2009
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt tb490bc trimmer cranks with start fluid but wont run
if it runs on starting fluid but dies after that runs out then you have a carburetor issue not supplying fuel to keep it running
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 25, 2013 | Troy-Bilt Garden
Gas dripping out of air intake on troy bilt trimmer TB525EC
The diaghrams in the carb could be starting to stiffen up holding the needle open. Does it start with no choke when cold? Rebuild the carb to replace stiff diaghrams
Oct 24, 2012 | Troy-Bilt 4 Cycle Straight Shaft String...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to replace air filter on Troy-bilt TB20CS?
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Jun 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt 4CC Trimmer - starts fine but won't turn off - TB425CS
Try cleaning up the switch button with Electronics Spray - you can get it from Wal-Mart for $3.
Usually is a bad contact or could be a broken wire .
Apr 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt Tb70ss Gas Trimmer Logo
660 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
