Muffled/bad sound on 1 channel of Marantz PM4400 amplifier
The right-hand channel of my Marantz PM4400 amp produces very distorted and low volume sound compared with the left hand side which seems to be ok.
Obviously I am no expert but I have tried swapping speakers, speaker cable and using different phono cable from various inputs so I think I am now fairly safe in assuming the problem lies with the amp. I took off the cover but could see only one glass fuse, it looked absolutely fine although I have not tested it (I don't know how!).
Does anyone have any idea what this could be and if so how I could repair it with my limited (i.e. practically non-existent) knowledge?
Thanks.
  • Audio Player... Master
  • 5,554 Answers
Go directly to the main amp, follow the leads from the speaker terminals. And you should find something on an heatsink. If there are two transistors see if they are running hotter than the other channel. If you see any damage to them (compare with good channel) replace both!
If all you see is a black box with pins coming out of it you need to replace that. They sometimes have the letters STK on them.
Replace both types with the letters and numbers of the same type. IE 2SC 1220 or STK 589.
Posted on Feb 16, 2009
I have a magnavox astro-sonic console the right speakers work at full strength but the left is muffled and when the volume is turned all the wat up it produces low sound.
Check the balance or fader control and turn it to the left channel and if that doesn't provide quality volume from the left try swapping the speakers.
If there is no improvement there is an amplifier fault...
Dec 11, 2017 | Magnavox Audio Players & Recorders
I have a Marantz Digital Integrated Amplifier PM75 and experiencing with LP's and CD's that I get a loud popping sound , thereafter no sound until after several minutes when it comes back on.
If the sound is common to both channels plus on different functions, it is either a part that is common to both channels or is in the power supply. It will be either in the main pre-amp or power amp, or power supply. If you can turn the bad sound down, it's before the volume control and it's unlikely to be in the power amp section. If you can't turn the bad sound down, it will be in the power amp section.
Remember stereo amps are two mono amps joined together. So the two channels have separate parts for each channel. However some use IC's that have both channels running in them, they can be suspects in this case.
Jan 11, 2016 | Marantz Audio Players & Recorders
Distorted sound / fuse blows off when changing amp class.
The class A switch adjusts, via an optocoupler, the bias on the output transistors.
I would check the standard bias and class A bias adjustments.
Mar 22, 2014 | Marantz PM7200 2-Channel Amplifier
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
My marantz stereo amplifier PM420 is having a problem of uncontrolled volume and distorted sound output..when putting on higher volume its switch relay on on its main amp. section switch off. Pls help.tnx
The part of the amp you switch in (to get more power) has failed, its probably only on the left or right channel, not both. Its either a pro-repair (expensive) or replace or live-with-it
Dec 14, 2013 | Audio Players & Recorders
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Poor sound from 1 channel on a PM 66 SE Special Edition. Changed speaker and wire, no change. The sound is muffled and lower in volume. Same happens when tuner is on, so must be amplifier. Hope you can...
Hi...
My 1st thought would be a broken contact or 2 inside on the main volume control... Is the balance set to middle?
Is it the same with headphones?
Sep 24, 2010 | Marantz Audio Players & Recorders
Volume at 10 produces very low speaker output.!?
It sounds to me that all you are getting is the pre-amp stage of the amp and nothing from the power amp stage. As it is on both channels then it is something that is common to both. This could be something to do with the power supply of the power stage. Or whatever is on the heatsink. It could be that the amp uses a single audio amp IC for both channels. If it does my bet is that it's gone. If it uses two sets of semiconductors for the right & left channel it would be highly unlikely that both channels have gone, but not impossible.
Dec 27, 2009 | Audio Players & Recorders
Marantz pm 7200 lost sound, only works when volume is up high, still looks like there are no high or medium frequencies.
You have either lost the pre-amp stage or the Main Amp stage. Since you have a problem on both channels it most be a part that is common to both channels. Something like an IC I would suspect.
Oct 31, 2009 | Marantz PM7200 2-Channel Amplifier
Sound from left channel is small and distorted.
The distortion might be caused by a resistor. The loss of volume could be the capacitors, but you could try injecting signals into the transistors to see if any has gone. They can cause the distortion and loss of signal. If you apply a soldering iron to any part it will heat up quicker, or you could also use a hairdryer for the whole thing. You can also get a freeze spray that cools things that have heat sensitive faults (available from electronic parts shops).
Apr 24, 2009 | Marantz PM-15S1 2-Channel Amplifier
592 people viewed this question
 Grubhead
Grubhead
