Question about IBM ThinkPad T21 Notebook
Will Not Power On
We turned the computer on and heard a series of loud beeps, so we immediately turned it off and unplugged it. Now we can't get the computer to go back on and the litle battery icon (above and to the right of the keyboard) is orange. The computer is totally dead. Please help! Thank you.
  • Michael Minkus Mar 26, 2007
    Thanks very much for your advice. Just to update the situation- the little battery icon is now green but the computer ( a laptop) is still totally unresponsive when I try to turn it on. Any help would be greatly appreciated. Thanks!
  • 57 Answers
Take out all the CRU (Customer replacable Units) from the laptop eg: RAM, HDD, CD/DVD, FDD etc). Connect each one individually one by one and the start the machine. Also, disconnect the Battery from the Laptop & Connect directly to the wall jack using the Adapter. Also check for the Power port for physical defects, and if found have the port replaced by a certified technician.
Posted on Mar 29, 2007
  • 60 Answers
Assuming that this is a laptop then it sounds like a few possible problems. Very common in laptops is a D/C socket problem. Even a Hairline crack were the power socket is soldered. This can be fixed try, www.laptoprepairspecialists.co.uk. Or it could be a problem with RAM. Depends how many beeps you were getting but a laptop will not boot without RAM. Any more help just ask.
Posted on Mar 26, 2007
MY TOWER KEEPS BEEPING, LIKE IT IS SYNCING BUT DOEST STOP MAKING THE NOISE. WHAT TO DO? I HAVE ALREADY TURNED ON AND OFF AND UNPLUGGED AND REPLUGGED.
Sounds like you might have a hardware issue, computers generally use a loud beep (not from the speakers or headphones) that alert the user that something has gone wrong with it. I recommend you take it in to a computer store to have it looked at. Issues like this might stem from overheating, which would cause your computer to immediately switch off in order to prevent components from further overheating.
Feb 27, 2017 | Tower Computers & Internet
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
Dell loud fan noise
Is the computer completing post? This is indicated normally by a single beep after the power button is turned on. On most computers the beep is proceeded by a post screen with the manufactures logo. If the computer is not getting this far, unplug everything but the memory and video. This should cause the computer to give a no hard drive or OS error. If not pull all the memory, this should cause the computer to give a series of beeps (because there is no memory installed). If this does not work either, you could have a bad mother board or power supply.
Hope this helps
Jan 26, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
I plugged in my tower and i heard a loud high pitch beeping sound the green led light in the back was on but the power button turns green and the green led light in the back turned off there is no signal...
the green led light is it beside the network cable connector. if it is so, then it is always meant to be like that when you power up your computer. it is not something serious and it is normal.
Aug 18, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Solid amber light, fan attempts to starts, but fails. I think it's a bad motherboard. How can I be absolutely certain?
I would suspect the power supply over the System Board.
You will need a large antistatic bag or antistatic mat plus a ground strap and a power supply checker.
Check the power supply using a power supply checker (about $10.00). Unplug the power connector on the mother board and plug the connector into the power supply tester. If you do not have a power supply tester let me know how many pins are on the connector and I will tell you how to test it with a volt meter. If any voltage is not present, replace the power supply. If you do not have -5 volts it was used for ISA slots and was completely removed from the ATX standard in 2004.
Do you have an onboard video card? If you do is that the video output you intend to use or a external video card? If you have onboard video connect the monitor to the onboard video output. Disconnect the AC power supply cord from the computer and attach a ground strap from your wrist to the bare metal of the power supply. The down side of static damage to components is you do not always see the damage immediately since static can weaken components causing future failure. Remove all cards from the slots except the video card if you do not have the onboard video. Be careful to touch only the edges of the boards not the connecters and place them on the antistatic mat or in the antistatic bag. Plug the power supply back in and see if the Power On Self Test (POST) displays the boot process on screen or beeps are audible. The error beep codes can change from the BIOS types but these are a few generic ones. It would be best to check your motherboard manual for a complete listing of error codes.
1 short beep – System is OK
No beeps – Bad power supply or system board
Continues beep – Memory error
1 long two short beeps - display adaptor
If no video is displayed and no beeps can be heard, turn the system off by holding down the power button for 5 seconds then unplug the unit. Verify the ground strap connection on your wrist and the bare metal of the power supply. Carefully remove the memory sticks handling only by the edges noting which slots they go in and which module was taken from which slot and place them on the antistatic mat or in the antistatic bag. Plug the power supply back in and see if a continues beep is audible. If yes, power off the unit and unplug the power cord. Put only one memory module in the first slot but do not put the same module in the same slot (swap them) if you have more than one module. Restore power to the system and see if the continues beep is no longer heard and you see video. If you see video and no continues beep than power the unit down and unplug the unit. Do the same for any other memory module which will help you determine if any modules are bad. This test is not a complete test but if any modules are dead you can identify them. If no video and no beeps the motherboard is the suspected problem.
If you have video and one short beep upon power on and all memory checks good. Power down the unit and unplug the power to the power supply inset one of the removed boards and try to boot the system to see if you still have video. If you do power the system down and repeat the same procedure for each card. If you do not have video suspect that card is bad.
Good luck and be careful to always touch the bare metal of the power supply with it unplugged before reaching inside the computer and touching any boards.
Aug 13, 2010 | Dell Vostro 200 Desktop Computer
Red blinking light
same problem, red blinking light in series of 5 flashes
May 30, 2009 | Pioneer PureVision Pro-1000HD 50 in....
Computer will not boot. was making some loud noise before it stopped working
I just had the same problem to deal with. My computer automatically turned on, and just when you thought it was gonna work, there was a single, loud beep. I immediately unplugged the computer. Make sure all the cords and chips are properly and securely connected. My problem was that my memory cards were loose. Maybe that'll help.
Jun 17, 2008 | HP Pavilion A1050y (PU131AV) PC Desktop
No post, only motherboard light on, green.
Hey there aj1253, It seems you are getting power to the board. are the fans running?Are you using onboard video or video card. Onboard is suggested for test. I would also suggest you reseat your ram. That is removing it and ensuring it seats properly. Beyond that I would ask you provide more info ( ie is this a new build, or did it just stop working, configuration details, model #'s, et....)
Feb 01, 2008 | Dell Dimension 2400 PC Desktop
Intel Media Series Intel G33 chipset micro atx no post no boot after crazy fan
make sure you have seated all the cards properly, take them out and reseat them including the ram. Make sure your IDE cables are plugged in properly as well.
Restart the computer and if still no post then yes unfortunatly for you its the mobo =(
Dec 03, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
IBM ThinkPad T21 Notebook Logo
121 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
