Question about Microwave Ovens
Microwave not operating correctly.
Report abuse posted by podolskifami on Dec 14, 2008
Recently I noticed that the microwave sounded like it was only operating on half power. In other words, the microwave sounded a little quieter than usual and it appeared to be operating slowly. Upon using the microwave a few more times, the power completely shut off. The power has since returned and I have normal use of the clock, lights and exhaust fan, however, I have the same "half power" problem. Any suggestions and can I fix this problem myself? Please respond to my company email at jeff@jbcpropertymanagement.com
  • Microwave Ovens Master
  • 9,125 Answers
It sounds like your internal cooling fan (not to be confused with the exhaust fan) is not working.
This will cause the magnetron to overheat until the magnetron's thermostat trips, killing power to the whole oven until it cools back down.
To help further, I would need the full model number form the tag on the oven.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Posted on Mar 16, 2017
MicrowaveSvc
  • 9125 Answers
SOURCE: Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Posted on Oct 12, 2006
MicrowaveSvc
  • 9125 Answers
SOURCE: Microwave Oven Problem
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. It's probably not actually heating with the door open, but better safe than sorry! If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Apr 10, 2007
  • 209 Answers
SOURCE: Microwave malfunction
this could be a diode between the capacitor and magnetron, (its like a fuse) i do not recommend self repair, but give you this info as a guide to what maybe wrong, microwaves contain high voltage and care should be used if you do attempt repair hope i have helped a little
Posted on Oct 04, 2007
MicrowaveSvc
  • 9125 Answers
SOURCE: Kenmore Microwave Model 721.80593402
This is usually a broken or misaligned door switch mount or possibly a bad door switch.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find an exploded view by entering your model number here: http://www3.sears.com
Posted on Nov 18, 2007
SOURCE: microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Posted on Mar 24, 2010
Testimonial: "Excellent. Thanks so much for your very quick and valued help! Will do as you suggest and give further feed back on outcome. Again, Many Thanks. "
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Frigidaire FMV158FMB power issue
Sounds like the door latch switch is broken and shorting out.
Feb 20, 2014 | Frigidaire Microwave Ovens
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Ge spacemaker xl1400 model# jvm141obc Turntable still turns..but while making grinding sound Please help
My wife noticed a strong smell of something burning inside our home. Luckily we were home. The microwave was NOT on...and the turntable was turning and making that grinding sound. When I opened the door, the turntable kept turning....all digital lights were OFF. The microwave does not work. I am extremely angry that this unit was able to continue to grind unnoticed. If we were not home, I assure you that this would have caused a kitchen fire. The upper inside portion was extremely hot to the touch and the cabinet on top of the over-the-range microwave was also very hot. This would have easily caused ignition and a subsequent kitchen fire. I am going to report this to the UL.
Feb 10, 2011 | Microwave Ovens
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
I have a GE Eterna Spacemaker Model Number EMO3000HSS05
Reduced power was selected, perhaps inadvertently
May 07, 2017 | GE EMO3000 Microwave Oven
Microwave oven has become very noisy
Oh, this is a UK/European model...
I have no info on that, so your best bet is to contact Panasonic UK:
http://www.panasonic.co.uk/customer-Support/index.asp
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 25, 2008 | Microwave Ovens
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
FUSE on Microwave still blows
Sounds like a power supply problem. There is a capacitor in the unit which often gives problems. This may be beyond non-professional help and may have been started when you had the other failure.
Dec 20, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
