Question about Kenmore 61282 / 61284 / 61289 Top Freezer Refrigerator
Refrigerator condenser banging
Tilted fridge to vacumn coils under fridge,releveled fridge by adjusting rollers,2 under front of fridge adjustable,2 in back stationary,kenmore fridge with freezer on top,fridge was quiet as a mouse until i decided to clean coils and relevel,now when condenser shuts off it bangs and rattles,when i manually shake condenser bowl sounds like a ball is banging against the inside,all rubber shocks are in good condition and soft,insulation is in place around conden.Hope you can help noise is driving us batty,Should have left well enough alone,Thanks in advance for your help.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 139 Answers
Yeah, you must have knocked the compressor when cleaning, sounds like one of internal spring/mounts in the comp' has dislodged.
replace the compressor is the only fix, unless you can somehow get to the lose spring.
Posted on Apr 25, 2017
3 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: Motor noise
You can remove the lower back cover panel and visually see the compressor and fan. Check the mounting bolts on the compressor to see if they are loose allowing the compressor to bounce around in there. You can also "stall" the fan with a wash cloth to stop the blade from turning (it's OK just try not to bend the blades). That will eliminate the fan squeaking as it coasts down to a stop. Better to stuff a wash cloth in while the fan isn't running. Turn the t-stat up to colder to force a run condition for a minute or two then turn the t-stat down and watch the compressor and listen for those sounds again.
Posted on Nov 11, 2006
muttandjeff
  • 359 Answers
SOURCE: Kenmore fridge with freezer on top/condenser bangs
check rubber mounts on compressor and also make sure fan is clear of anything that could be rubbing it
Posted on Feb 03, 2009
Need to rebalance refrigerator
Hi Susan ! If you look under the fridge at the front you can see the front two feet at either side. Both of these feet are adjustable, a collar on a threaded PVC foot with normally a straight roller at the bottom. You will need to roll the fridge out a little and using some one to help tilt the fridge back a little to get your hand on to the collar. Some are able to be turned with just your fingers with out tilting the fridge but it is easier with the weight off them. If door self closes the fridge is tilting back, tilting forward the door will stay open. Now by loosening or typically threading the collar anti-clockwise the foot height will reduce and the fridge will become more level and the door will close slower. As you get it just right to your personal liking just wiggle the fridge a little and make sure all the feet are touching the ground. The use of a level and patience can have you set it up just right for you.
I hope this helps as myself being a fridgy like my fridge door a certain way, customers like sometimes know how they like it and there is the way the fridge is ideally installed.
Mar 20, 2014 | GE GSS22JET Side by Side Refrigerator
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
Are back feet/rollers adjustable?
normally the rear are just rollers
for your problem use tapered door wedges ( hardware shop) under the appropriate side at the rear of the fridge to make the adjustment
Sep 04, 2017 | Electrolux EI23BC51IS
How do I adjust the 'feet/roller' at the rear of the unit in order to ensure the unit is level?
there are two allen head type screws one under the freezer door hindge side one under fridge side hinge insert a large allen wrench long handle type and turn clock wise to adjust the back wheels be carefule if you turn counter clockwise the long screw will come out of the adjustment nut in the wheel bracket. then have some one tilt the fridge back and next to the allen wrench you will see a white disk that is the adjustment eor the eront of the unit turn it clockwise it will spin down as you turn it.
Jun 28, 2011 | Bosch B22CS80SNS (220 cu ft) Side by Side...
My side by side fridge door does not close by itself when released
It is likely that your fridge is tilted left or right, and possibly forward at the same time. Most refrigerator doors will self-close if the fridge is slightly tilted both back and to the handle. The fridge is raised or lowered by adjusting the front feet or rollers.
The problem you'll encounter with a side-by-side fridge is that if you adjust for the right-hand door to self-close, there's a good chance that the left-hand door will want to stay or fully open; if you don't check it while making the adjustments. It can take a little extra time to make sure the adjustments make the front both perfectly level left to right, AND slightly higher in the front than the back.
Please rate this reply if you found it helpful - good luck!
Aug 03, 2010 | Refrigerators
Refrigerator does not level tilts to rear extremly unit rolls foward when opening doors
there should be two set screws at the top of the rollers . to adjust if I am correct you turn these screws to the left to raise the front. These screws are above the rollers as I said however, if you use a phone book to hold up the front of the fridge it will take pressure off the rollers making their adjustments easier
Good Luck
Dave
Aug 28, 2009 | Jenn-Air JCD2389G Side by Side...
Gshl5kgxls refrigerator is tilting.
well the simple solution is wood shims to level it out. Could just be your floor is not quite level. I use the cheap pine shims that you get at the hardware store.
Jun 19, 2009 | General Electric GSHL5KGXLS Stainless...
Dec 17, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
NOT LEVEL
Lower the front. But the back needs to be slightly lower that the front in order for the door to swing shut atomatically. While your working under the front, check the condenser coil (wire racks, usually 2-3 layers with a 1/2 inch space between them). Use a vaccum cleaner and **** out any dust. This will make the refrig run less and cool better.
Sep 15, 2008 | Hotpoint HTS18 Top Freezer Refrigerator
Kenmore 61282 / 61284 / 61289 Top Freezer Refrigerator Logo
211 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
