Question about Frigidaire GLTF2940ES Front Load Washer
E70 We have a frigidair front load washer Model #GLTF2940ES0 and every time we do a load of laundry regardless of the amount of laundry it does E70 and in order for the washer to continue we usually have to put it on drain and spin. If you have any suggestions we would greatly appreciate it. Bobby
    President:
  • 1,294 Answers
All w/machines have a maximum load capacity. Look for yours in the users'manual. Overloading could give you problems, bearings, etc. Your machine cld even have a half load switch.
Posted on Apr 11, 2007
Check the hoses, make sure the hot and cold are on right at both ends :)
Posted on May 28, 2007
Will a Frigidaire Front Load Pedestal for model GLTF2940ES0 fit other brands of front loaf washing machines?
If the foot print (base dimensions) of the new washer is the same it should fit. Make sure it fits in to the holes in the base as you don't want it to wiggle off the base when it is in spin mode. Or you could drill holes and screw the base and machine together.
Dec 30, 2014 | Washing Machines
Our Frigidaire GLTF2940ES0 washer was in spin cycle with 7 mins to go when is just stopped. No specific error code other then Err. It will not start at all now. Door locks and unlocks fine.
Sounds like the electronic locking mechanism is malfunctioning. It is secondary lock which is supposed to enguage before the high spin cycle. It is about a $20 part.
Sep 15, 2011 | Frigidaire GLTF2940ES Front Load Washer
I am getting an error E70 have a frigidair Affinity Washer
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.
Hope this solution will fix your problem for sure.
Thank You !!
Jun 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code E70 on my Frigidaire front loading washer model LTF2940FEO
The hot and cold water hoses were connected wrong to the washer.
Dec 22, 2009 | Frigidaire Washing Machines
OK I have a frigidaire front load washer model #GLTF2940ES0 it won't start but the lights are on. I push the button and it blinks err then lock. what can I do?
hello mam
after taking the water to its drum to a given level it should start the thumble wash and if it wont then we should check the timer switch,motor,and the water level controler.so please call the engineer.
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES0 won't pump or spin
Sounds like a water valve solenoid. The hot and cold water is controlled by solenoids that open and close. Try running just the hot and just the cold. If one or the other works, then the proble,m is a bad solenoid valve
May 28, 2009 | Frigidaire GLTF2940ES Front Load Washer
Laundry Detergent
this usually depends on the type and brand of detergent you use. for example if you use standard detergent and it takes 1 cup, then you use concentrated detergent and it takes 1/2 cup. you have to check the detergent container for proper amount to use. for most detergents it is around 3/4 to 1 cup of detergent.
Ps. dont forget to rate my answer please. Thanks.
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Nov 30, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
440 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
