Question about Coleman Powermate Powermate 5000W Generator
5000w gen. no powe out put
I have 500w powermate (Colman) generator no power out put , motor does run?
  • 98 Answers
When engine runs but no power is produced ...there are three things you need to check:
1- brushes may be shattered.(open the generating unit cover(from the stator and rotor side) and you'll find it..if it is shattered..then replace it.
2- breaker...to test this disfunction...connect the two wires(the one going to it and the one coming out of it) together and try again...if it generated power..then the breaker is out of order...either replace it...or keep it connected directly (DON'T leave any naked wires)
3- AVR open the generatng unit cove again.you'll find the AVR (screwed to the rotor holder) here is a picture of an AVR:5000w gen. no powe out put - 93c8b52.jpg if it is burnt out...replace it..
IF you tried the 3 things i wrote and none of them worked, then you have a problem with the stator or the rotor...but that is very rare to happen...it's probably one of the three///..
Posted on Oct 26, 2009
How to troubleshoot a gasoline powered generator
What might you be trouble shooting may I ask. Or go find your owners manual online at Colman.com.
Mar 15, 2016 | Coleman Powermate Powermate 5000W...
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Does the colman powermate 5000 have a full sutoff valve? where is it?
yes it does at the botton of the fuel tanl were the fuel line goes it may look like a round know, if it is a Briggs motor it also has a fuel pump that has it's own problems
Aug 25, 2011 | Coleman Powermate Powermate 5000W...
HOW DO I USE THE 240 CORD THAT CAME WITH MY 5000W. COLMAN POWERMATE
It is a twist-lock plug, just push it in and turn to the right. Link to the manual:= http://www.powermate.com/pdfs/2007/11/17/manual_pm0435003.pdf
Jun 13, 2011 | Coleman Powermate Portable Generator...
Have older powermate 5000 contractor gen. runs great but only puts out 5.5 to6.1 volts. has new brushes
Hello. Plug something into your generator's receptacle, say a trouble light. Then check the output. With no load at all [nothing plugged in, you will get a voltage reading that is low. regards, Joe
Jan 28, 2010 | Coleman Powermate Powermate 5000W...
I have a 5000w colman generator w/ 2 standerd 120v outlets, 1twist 120/240v outlet. the grounding prong goes out all i can find are cords that go in ???
Go to an Electric supply store and tell them it is a 20 amp plug. They should be able to get the correct plug.
I had this generator and had to adjust the prong to make it work.
Jan 08, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
632 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
