Question about Autodesk AutoCAD LT 2002 (05722-008108-9000) for PC
I keep getting the same message while using autocad 2002lt
The same message has been recently appearing and re-appearing. I get a message that states "internal error-gedit 3" as soon as i click 'ok' it prompts me to save my work then it shuts down.... please help!!
  • 4 Answers
There are a few things to try. I'd try this first: Start ACAD and use the Recover command (File menu) to open your drawing. If that doesn't you can insert your drawing into an empty drawing as an exploded block and/or purge your drawing.
Posted on Dec 20, 2008
Laptop boots to main screen OK, but as soon as I click any icon, the screen goes completely white and won't respond at all. What can I do?
do a Sytem restore to an earlier Restore Point:
Start the System Restore Utility at a command prompt
1. Restart your computer, and keep tapping F8 during the initial start-up until you get options, select Safe Mode with a Command Prompt then press enter.
2. Log on to your computer with an administrator account or with an account that has administrator credentials.
3. Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
4. Follow the instructions that appear on the screen to restore your computer to an earlier state.
Look for the most recent system checkpoint created before the errors to restore from.
http://keith.geekstogo.com/systemrestore.htm
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 02, 2011 | E-Machines M2350 Notebook
Good Morning Sirs, I was wondering to know, after having installed Windows 7, on my HP DV9000 Series Laptop, shift 2 = at and Shift 3 = hyphen are not working, in that place of @ and £ are...
The keyboard layout / Language of your PC may have been changed, so follow these steps to select the International keyboard layout:
- Go to Control Panel - Region and Language settings
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout.
- Click the Language bar, and then click United States-International on the shortcut menu that appears.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 10, 2010 | HP CPQ175KB Keyboard
Code 507 with circle as soon as i switch it on wont let me do anything else
Error 507 appears when any subsequent attempts to perform an Application Load or upgrading the software
on the BlackBerry smartphone are unsuccessful
Solution :
1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2. Click on the Application Loader icon.
3. Click Update Software.
4. Type your BlackBerry smartphone password (if prompted) and click OK.
5. Select Options under the Device software options section.
6. Select the check boxes next to the names of the applications you want to install.
7. Click Settings, and remove the check mark from the check box for Back up device data automatically during the installation process.
8. Click OK.
9. Click Next > Finish.
10. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
If it shows the same error then please visit to the nearest Service centre.
Oct 31, 2009 | RIM BlackBerry 7290
Auto cad internal error problem GEDIT 3
Hi there.
Uninstall AutoCad again and download CCleaner from here >>>>
http://www.filehippo.com/download_ccleaner/
Once downloaded use the cleaner to get rid of any temporary files that are in hidden folders on the computer then use the registry cleaner to remove any registry entries or unused file extensions.
You will see in the screen shot CCleaners registry tool, where is says scan for issues click on that, once it's completed click fix selected issues, it will ask you if you want to back up to the registry, click on yes and save, keep on scanning for issues until it says no issues found.
Restart the PC and then reinstall AutoCad, hopefully the problems will be solved.
Please post back with the results.
Good luck and thanks for using FixYa!!
May 27, 2009 | Microsoft Computers & Internet
Acer KB 0759
I would sure check the Region and Language setting in the windows control panel. Make sure it says U.S. (english).
Apr 02, 2009 | Acer NSK8458AN Keyboard
Computer is having trouble connecting to hard drive LaCie 300 GB
That error message usually means the drive is working intermittently (writing to the disk), and drive failure occurs shortly thereafter. You might try a different connection mode (USB?), and make sure you have everything on that drive backed up or copied elsewhere.
May 02, 2017 | LaCie D2 Extreme 300 GB Hard Drive
Internal Error 2738
Since you are running windows vista please follow these instructions carefully.
  1. Click on "Start".
  2. Click on "All Programs".
  3. Click on "Accessories".
  4. Right click on the Command Prompt, select "run as administrator".
  5. At the prompt, type "regsvr32 vbscript.dll".
  6. You will now get a message box saying "vbscript.dll" has been registered.
  7. Reinstall QuickCam
I hope this helps. If not let us know.
Please rate my answer
Aug 15, 2008 | Logitech QuickCam Communicate STX Webcam
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
Shutdown
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
Autodesk AutoCAD LT 2002 (05722-008108-9000) for PC Logo
653 people viewed this question
Top Autodesk Computers & Internet Experts
gchwood
Tom Chichester
Alexey Krenvalk
Alexey Krenvalk
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
