Question about Toys
Touch screen not working
Hi, only had my sons Laepster 2 for a week N when you try to use the touchscreen with the pen to choose your name , nothing happens......I would appreciate any ideas her as like I said , only had it a week and bought 3 games to go with it and they dont come cheap???????
  • 1 more comment
  • pegasus1975 Jan 07, 2009
    I have exactly the same problem!! And only had it for 2 weeks!
  • Smeagol300 Jan 08, 2009
    I have changed my daughters Leapster 2 just 2 days after Christmas about a week later is has broken again. Is this a known fault ?
  • bwwertz Jan 30, 2009
    I have tried to recalibrate using the stylus, but when I pull up the recalibration screen, I am unable to view anything at all on the screen - no cross hairs - no nothing. Depsite adjusting the contrast. Please help! Thank you.
Hpoe this helps, had the same problem with my son's leapster2, took it back got a replacement and the same thing happened within 5 minutes of turning it on!! Finally found this advice on the net.
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint button while turning the unit on
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Good luck, seemed to work for ours
Posted on Jan 12, 2009
We realised that the leapster needed calibrating ...works fine now, and it was very simple to do!
Lol I just took mine back again. I would have thought a major outlet like Toys R Us should know about the calibration and advised me but to be fair to them they did exchange again without any fuss.
Thanks for the advise I will know for next time.
  • adincj12 Jan 25, 2011
    perfect!!! Ithe stylus did not work and I followed this directions and they worked again! Thank you!
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
When the main screen comes on and says touch your name with the pen it does not resond what do i do?
It sounds like the TouchScreen needs to be calibrated.
1. Hold down the Hint button while turning the Leapster on.
2. When the Leapster menu screen appears, press the A button.
3. Touch each of the crosshairs that appear with the stylus.
4. Restart the Leapster.
Hope this helps!
Feb 27, 2011 | Leapster 2
Touch screen does not work, can't select name. Tried on off
Switch off the console and switch it back on again holding the ? button down. This takes you into a menu, choose the touch calibration, it will take you into a black screen with a cross in one of the corners, touch this with your pen and then touch all the others as they appear, all corners and the center. Once this has been done it will take you back to the menu screen again. Switch the console off and on again and it should work. :)
Dec 13, 2010 | LeapFrog Leapster 2 Learning System
Pen not working on screen to use
Hi, have you tried to recalibrate the screen as in your instructions?
Make sure you have no game inserted
Press and hold down the 'on' button and 'hint' button (with questionmark on it) at same time until a menu appears on screen
Press A
Now touch all the little crosses with your pen that appear on the screen
switch leapster off and restart
if still not working, repeat above
Jun 15, 2009 | LeapFrog Leapster 2 Learning System
Leapfrog Leapster touch screen
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Apr 10, 2009 | LeapFrog Leapster 2 Learning System
My nintendo ds lite the touch screen does not work
if your touch screen is non responsive I can replace it. I have new touchscreens in stock for $24.
ninja_freak318@hotmail.com
Dec 07, 2008 | Nintendo DS Lite Console
The Pen
I'm not familiar with your laptop but judging from all the pdas I've had with touch screens the pen itself is only a pen, you could basicly use a wooden stick to poke at the screen and it shouldn't make a difference to the computer.
this laptop has a touchscreen If I'm not mistaken and you should be able to use it even with your fingers.
You might have a faulty touchscreen or then you need to install a driver for the screen?
Jul 04, 2008 | Averatec 3500T60 Tablet PC
Leapster LMAX touch screen calibration not working on center dot.. games not being able to read
I just bought the "new" leapster 2 and it loads but it doesn't do anything when touching the screen with the pen.... It asked me to choose my coutry which i did .. took 10 mins then it picked the wrong country.. now i am stuck at putting in my son's name.. again won't do anything..
Jun 07, 2008 | Video Game Consoles & Games
Got my son's to work. Used these instructions.
Question Why doesn;t my Leapster2 respond to the stylus pen? trnsp.gif Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 11, 2008 | Nintendo Game Boy Advance Console
Toys Logo
1,044 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
