Question about HP Deskjet 6940 InkJet Printer
I need to change the ink cartridge, but i can't get it out
  • Anonymous May 06, 2009
    I have the same problem. There is a bar underneath the cartridges that the cartridge cannot get over. In other words, it can't slide straight out. If I work really hard, I can wedge it over the bar, but then the L-shaped portion gets stuck.
    The bar has a sticker with a picture of the power button.
  • 38 Answers
Look at the directions on the new cartridge on how to put it in and then do everything in reverse to get the current cartridge out of the printer.
Posted on Dec 17, 2008
I changed theblack ink cartridge twice and it still won't print in black, colours are printing but no black
Ink level data is stored in a chip of the cartridge. Once the cartridge is empty, ink low message will appear eventhough you refill the cartridge. You need to deactivate ink level detection function to continue printing in case of usage of refill ink .
Search google on how to change ink level detection
Chris Thrash
B52Computers
Jan 10, 2011 | Epson Office Equipment & Supplies
Printer doesn't revognize new ink cartridge
Are you using Dell Series 5 ink cartridges? Dell Series 5 ink cartridges have a cartridge that cannot be reset.
Article on refilling Dell ink cartridges
It's possible to get a bad Dell Series 5 ink cartridge. Return to place of purchase for a replacement.
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Jan 13, 2010 | Epson Stylus C46 InkJet Printer
How to change ink cartridge in epsonnx110
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
107 people viewed this question
Ben Johnson
