Question about Toshiba 42HL167 42 in. LCD Television
I have the toshiba 42hl167 and the volume is not working. only works with play station. cant here cable or bose system.
  • 8,596 Answers
I would reset the factory defaults on the TV, but some complicating information follows these instructions:
Reset Factory Defaults
To reset all settings and channels to their factory
default values:
1 Press Y and open the Setup menu.
2 Highlight Installation and press T. A new set of
Installation menu icons will appear.
3 Open the System Status menu, highlight System
Information, and press T.
4 Press C c to scroll through the menu bar to select
Factory Defaults.
5 Enter your PIN code (or 0000 if no PIN code has been set).
Because the PC and HDMI-1 inputs share the same set of analog audio inputs, the PC Audio menu setting influences the HDMI 1 Audio menu setting. If PC Audio is set to “No,” the HDMI 1 Audio setting changes to “Auto.” If PC Audio is set to “Yes,” the HDMI 1 Audio setting is set to “Digital” and is grayed out in the menu. (Also see item 5 on page 12 of manual and “Setting the HDMI™ Audio mode” on page 43 of manual).
There is also some good information on pp.20-22 and 54-57 of the manual - this one has a lot of audio hookups and settings.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Speakers bose docking station make a noise
Have two Bose docking stations and the oldest (white) one have some problems now. When I put in one of my iPods in the docking, the speakers make some weird, creaky noises. Kind of a sound, when I'm looking for a channel on the radio. When I wiggle a little bit the connector from the docking station, it will play some music for a short time. Still it is not the same quality sound, it used to be. Also, some times the sound is too loud and when I touch ONE time the volume minus (-) button, you can hardly hear the music, it is too soft. Hope somebody can solve this problem.
Sep 10, 2012 | Bose SoundDock digital music system...
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
Ipod charges on bose dock but won't play ipod firmware 3.1.2 recently updated
i have bought a ipod nano and i want it to work in my car stereo it charges but does not play it does play my sons ipod touch so the cable is ok
Feb 07, 2010 | Bose SoundDock digital music system...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
The volume does not work
try turning the volume up on the bose system
Aug 08, 2009 | Bose SoundDock digital music system...
Bose docking station problem. Remote will not work on either my ipod touch or I Phone. The volume buttons work on the remote but the skip and pause/play buttons do not. The Bose is brand new and straight...
If it is brand new. It is under warranty. Go back to the store where it was purchased and tell them the problem. They should replace it with another new one. Have them show you how to use it on all of the functions on your Bose Docking Station. Make sure you tell them about the ipod Touch and the iPhone.
Jun 07, 2009 | Bose SoundDock digital music system...
No audio on my Toshiba TV
Found this on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
Models: 20DL77, 20HLK67, 26HL47, 32HL17, 37HL17, 42HL17, 26HL37, 32HL37, 20HL67, 26HL67, 32HL67, 37HL67,
42HL167, 42HL67, 47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00128
1. Please check your connections and make sure if you are using COMPOSITE “yellow, white, and red cables”, SVIDEO,
with “white, and red” or Color Stream COMPONENT “green, blue, red, white and red cables,” that the white
and red cables which are used for audio are plugged in securely into the same inputs as the video.
If your connections are secure, the station may have broadcast difficulties. Try a different channel.
2. If you are using the coax cable from the wall, press the “ENTER” button on the middle of the remote. If the
information provided shows that you have SAP selected we will need to change it to STEREO or MONO. To do
this, we will need to press the “MENU” button, and use the RIGHT or LEFT arrow keys to highlight the AUDIO
menu. Next we will need to use the DOWN arrow to select AUDIO SETUP press “ENTER” and then arrow down to
MTS and use the RIGHT arrow to select stereo.
3. If you have a cable box or satellite receiver, please make sure the TV’s volume, as well as the box’s, volume is
turned up sufficiently.
4. The station may have broadcast difficulties. Try another channel.
5. The sound may be muted. Press VOLUME.
6. If you still have problems after following these steps please contact Customer Solutions at 1800-631-3811 Monday
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811.I hope this helps you with your problem.
Jan 14, 2009 | Toshiba 42HL167 42 in. LCD Television
No sound on my Toshiba Regza 42HL167
Found this troubleshooting method on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
REF:FAQLCD00128
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811. I hope this helps you with your problem.
Jan 06, 2009 | Toshiba 42HL167 42 in. LCD Television
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
No sound from my TV!! HELP!!
assume its a bose system 12 (non digital or digital ?)
if you clarify the model of both tv and bose system i will tell you precisely how to connect tv to bose system,
but i must assume first that your cable box is connected to your tv via a scart cable , you must remove sound function from the cable and plug directly into cd5 unit on either auxillary or video input , then turn cd5 unit to that channel to play sound and use bose reomte to control volume (ok)
i would doubt thatthe TV has a audio output, many dont.... also it may be necessary to buy a scart to RCA cable at your local electronics shop or supermarket to completet he task at hand.
if however you are digital.....
make sure you are connectiong bose digital input to a digital (dolby 5.1 compatible) sound source.
sorry if you think i have over simplified the problem !
respect
Dec 02, 2007 | Bose Lifestyle 12 System
Toshiba 42HL167 42 in. LCD Television Logo
356 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
