Question about Rockford Fosgate P3001 Car Audio Amplifier
My amp wont give me any power
I have a p3001 amp had it hooked up for couple of months with know problems and one day just stop working and now thermal light wont go away any ideas will it work again !!!!!!
  • blueextc3221
    blueextc3221 May 11, 2010
    Driving the amplfier @ too low impedence?
    What is hooked up to the amplifier?
    You may have damaged it internally, and to repair... see a tech.
    Scholar:
  • 96 Answers
All the p series amps were discontinued for similar problems, they have a newer model out now. they have very weak boards internally and failed faster when mounted to the sub enclosure or very close to it from subsonic vibration. i would guess the amp is toasted.
Posted on Jan 07, 2009
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford P3001 amp not working
peel the cover completely off the amp and give it some power- if the amp is blown there will be a tiny light lit up on the circiut board that quite simply says "SHORT"-If its blown then theres nothing you can do unless you are a badass of course- but if the amp is dear to you and you want to spend a little money on it to get it up and running again- go to rockfords website and get into the forums and ask the question-where do i get my fosgate fixed and it will pull up some mumbo jumbo but it tells you about a place called LANDIS TECHNICAL that bought up all the parts to their amps and is in the business of restoring the amplifiers to their factory specs and even sends you a new power certificate to go with your new and improved amp.hope that helps you-
May 26, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Contracts or expands, and just stays there
bad connection check spk wiring and rca out behind radio make sure connection is rite
Apr 04, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
No power
You need to confirm that you have voltage on the B+ and remote terminals and that you have a good ground. Do you have a multimeter?
Apr 12, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Amp does not power on, flickers when cable disconnected.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 05, 2007 | Car Audio & Video
Amp turns on but doesnt power my subs
well ill need 2 know wat knobs are all on the front of your amp
Nov 07, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Thermal light won't turn off...
Check your speaker load ESPECILLY if you are bridging your speakers. Sounds like you may have a very low ohms load and it is frying your amps. Do this BEFORE you hook up another amp. If you are using dual voice coil speakers it is very easy to get the impedence (ohms) wrong in your hook up. If unbridged then a 4 ohm load per channel is good. If you are bridged, then an 8 ohm load is best. When you combine speakers, that is when most people get in trouble. Good luck.
May 09, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
RF P3001 power problems
check your sub woofer connection if you have multiple subs the could be wired in a parallel or with has to many ohms that my cause it to not hit right and cause the amp to get really hot and cut in and out
Nov 15, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate P3001 Car Audio Amplifier Logo
237 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
