Question about Fujitsu Plasmavision PDS-4233 42 in. Television
Error condition 3 message.
It only sees the rgb inputs. The repair service said that the eprom got flashed from a power surge but hus people want to sell him the whole input board which would cost around 1000$ Does anyone no howto or where to get the bin file for this model?
  • 97 Answers
I agree with the service people. Replace the board or contact Tristatemodule.com . Many shops use rebuilt boards from this service and they have a 1 year warranty. They will test it first and repair it if it is faulty. Do not flash it due to the EPROM may have emf damage.
Posted on Apr 10, 2007
How do I fix Error message 5E on samsung refrigerator RS267TD which popped up after a power surge? I have already unplugged it for 5 minutes
I must admit I know nothing about modern computerised fridges, though I do know a bit about computers.
If you don't have your computerised appliances surge protected - modern tv and radio, hi-fi, fridge and so forth are in reality either computers or contain computers - one or more of them is likely to be damaged by a power surge or voltage spike.
Sometimes even with surge protection they can be damaged.
Bear in mind if damage has occurred it is possible the error message means little or nothing.
I suggest you read the instruction manual and then contact the manufacturer's customer service for advice and then perhaps ask a local repairer the same questions.
Jul 06, 2014 | Samsung RS267TD
Different Colours Flashing....
If it works then consider it a bonus for you
Feb 08, 2014 | AOC Televison & Video
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
My Washer is flashing an error message. F27
Error code f27
OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
Check
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Good luck
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Green light is on ...white noise sound but no picture
This TV finds the connected input sources
automatically for AV1, AV2 and Component 1-
2. It is presumed that RGB and HDMI/DVI
sources are connected.
Check your setup to see if the audio is turn off but if you have a clear picture you should have sound.
Time to call a TV Tech if you are not going to repair the unit.
Jul 11, 2009 | LG 42PC3D 42 in. Plasma Television
Getting code H 3
The printer repair guy just left. I'm paraphrasing what he told me:
The Sharp MX4501N was displaying the error: H3-04. This does mean that the printer was reading an above average temperature for the fuser, for some reason.
He said that in his experience, 90% of the time, this is due to power surges/spikes and not an actual incident of the fuser over heating. A good surge protector isn't normally enough and he recommended that we look around for a cheap UPS to condition the power.
Other things that can cause a higher than average reading of the fuser can be caused by paper jams, where a piece or pieces of the paper are lodges inside, insulating the fuser and restricting air flow to the internal compnents. Printing 15-25 blank sheets through the copier can usually dislodge these. If not, call for assistance.
In order to clear the error code (H3-04) from possible powewr surges/pikes, I was given the following code: #P, *, C, 1,4 PRINT
This will remove most of the codes restricting printing to the copier, however, should the code reappear, contact customer service and arrange for a visit from the local repair person.
I hope this helps anyone else who may run in to the same problemThe error: H3-04. This does mean that the printer was reading an above average temperature for the fuser, for some reason.
90% of the time, this is due to Power surges/spikes and not an actual incident of the fuser over heating. A good surge protector isn't normally enough and recommended that we look around for a cheap UPS to condition the power.
In order to clear the error code (H3-04) from possible power surges/pikes, I was given the following code: #P, *, C, 1,4 PRINT
May 11, 2009 | Sharp AR-5316 Advanced Digital Imager...
Not powering up .supply fine
remove your cmos / bios battery for 2 0r 3 minutes, reinsert it n turn on yor comp.
Apr 09, 2009 | E-Machines eMachines Desktop PC
Canon Pixma ip3000 flashing amber 6 times
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Jan 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Service manual for gm338
http://www.motorola.com/governmentandenterprise/contentdir/zh_CN/Files/ProductInformation/GM338_Aus.pdf
Feb 11, 2008 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Fujitsu Plasmavision PDS-4233 42 in. Television Logo
139 people viewed this question
Top Fujitsu Televison & Video Experts
David Bukovaz
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
