Question about Magic Computers & Internet
HP Desktop I have a HP Desktop of 80GB dard drive with 4 partion.I tried to merge C-drive with D-drive with the help of partition magic software.while doing so, in the final stage my computer takes restart.My computer did not start showing DISK ERROR.How to get rid of the prob.please suggest. Thank u.
    Problem Solver:
  • 11 Answers
Hi
The same thing happened to me also with one pc I have running windows vista ultimate and freeBSD.
Delete all partitions, format to NTFS and do a clean install of windows, and for a 80GB drive just use one partition for the whole drive and install windows on that drive, set the bios to boot from CD and during install windows will use the whole drive as 1 physical drive.One Partition and you should get about 72+GB MIN. You will not get a full 80gb due to the way windblows measures a mb= 1000b rather than 1024b and also special hidden files, recycle bin, drive info, and partition info, boot sector etc.
HTH
Zues
Posted on Dec 21, 2008
HOW TO SET ORIGINAL SIZE OF HDD SEGATE BARRACUDA ST380011A THAT I WAS SET TO LIMITED SIZE I.E. 32GB NOW I WANT SET IT TO 80GB WHICH IS ORIGINAL SIZE.
you could do it by reformatting your hard drive which would mean loading your operating system again during the formatting process you will be given the option to select a partition or to select another or resize or download some software either partition magic which enables you to rezize your your already partitioned hard drive without losing any of you data http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Aug 24, 2012 | Seagate BARRACUDA Computers & Internet
My PC has a 70 gig hard drive Its partitioned into C and D C is full How do I remove the partion? Thanks Jim
If the drive is too full delete something that you can live without. Click on the link i have provided below, download and install Easeus Partition Manager. This tool will help you to re-size or merge the C drive to expand hard drive space and it only takes between 5 and 10 minutes to learn and execute.
http://download.cnet.com/Easeus-Partition-Master-Home-Edition/3000-2248_4-10863346.html?tag=mncol%3bpop&cdlPid=10982635
Please let me know how you get on or if you need anymore help.
Good luck.
Jan 17, 2010 | Sony VAIO PCV-W600G PC Desktop
Shows hard drive into 4 sections soon uses gb upon main hard drive but others show plenty of gbs left how to put into one drive
Use Partition Magic. It is software that will Re-Size, Merge and Create a hard drive partition. Here is the download link for you pal:
http://www.softpedia.com/get/System/Hard-Disk-Utils/Partition-Magic.shtml
I am sure this could help you a lot. Thanks..
Dec 18, 2009 | Excelstor Technology J880 Hard Drive
80gb harddrive that only says it has 34gb
Using a program like Parition Magic would allow you to adjust the partition size of your current partitions. It is possible that Compaq has used some ot the hard drive space for its recovery and restoration software. You could combine the current partitions into one larger partition. It is also possible that another partition exists using a Linux or other non windows operating system.
Mar 14, 2009 | HP COMPAQ Presario SR5410F Pentium...
Partition problem
In my humble opinion, the best option is to install a second (blank or larger) drive. Install some recovery software such as "easy recovery pro" or something that will be able to read files from a filesystem that has had the partition table written over. Start with trying to scan using FAT32, and in failing that, try NTFS. Restore the data to the second drive, format the first and partition as required. Copy the data back to the first drive to the partitions that you specified, and erase the data from the second drive. A free option may be pandora recovery, available at http://www.pandorarecovery.com/features/
Jan 20, 2009 | Microsoft Windows XP Professional
Partition Problem
Yuou must backup the data of d:\ in another harddrive or volume before doing this backup your data in another volume and then merge the data you can even copy the sectors from partion magic .Data can be recovered by using data recovery softwares.
Error 983 partion Magic
try to use hard drive partition software.
something like Maxtor, partition magic, etc.........
Nov 09, 2008 | Computers & Internet
Running out of space on C drive
hi, its possible to merge two partitions.
down load a partition changing software like partition magic and install it. Have a look at the help available and and go for merge partition.
thank you
Aug 15, 2008 | Microsoft Windows XP Home Edition
Hard drive
You can install a software called partition magic and use it to merge the two partitions into one.
But you might need to free some space on your C drive. What you can do is copy (CUT) all your My Documents data and paste it to your D drive or your second drive. This should free a lot of space enough to install partition magic.
You can download the trial version software from http://www.soft32.com/download_151.html
Install it and merge your partitions and then you can uninstall or purchase if you want.
Lolita
Apr 08, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Installed 2nd internal Maxtor 4R120LO 120gb HDD as a slave
Your Ques is not so clear. i think you prob is this. your c drive is not havin enough of space. normally you shuold have about 20 gb if you are using big softwares like photoshop.try to get your primary partition more space..Need more help?
Mar 10, 2008 | Maxtor Hard Drive
Computers & Internet Logo
328 people viewed this question
Top Magic Computers & Internet Experts
Computer Links
john h
Andrew Taylor
Andrew Taylor
Are you a Magic Computer and Internet Expert? Answer questions, earn points and help others
