Question about Honeywell Programmable Thermostat Heater
Chronotherm III Thermostat Completely Blank Screen, No Heat
The screen on the thermostat is completely blank. No reading at all and the heat is clearly not on because it's freezing in my house. I have changed the batteries and still nothing changed. Please help me. I live in CT and it is quite cold right now.
  • 24 Answers
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Posted on Dec 18, 2008
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Chronotherm 4 plus
change the batteries in the thermostat
Mar 21, 2014 | Honeywell Heating & Cooling
I cant get the ac ( cool ) to work , it read HOLD @ 82 degrees. I'm sweating over this
Hello my name is Heath it will be my pleasure to assist you. Your thermostat may be on the blink and need to be replaced. But first lets try a couple things first take the batteries out of the thermostat and let the display go completely blank ( aprox. 5 mins.). While that is going blank go to the indoor air handler and turn the power off to it either from the switch or the inside panel box. Then once the display has gone blank turn the power back on and put the batteries back in. Then set the switch to cool and turn the temperature down and press hold and try it like that to see if it goes back to heat if it does then the thermostat is changing the temperature on its own and going into heat mode and will need to be replaced.
Sep 11, 2011 | Heating & Cooling
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
Aux heat light is dimly lit when A/C kicks on. It's a roughly 10 year old Chronotherm III.
Take a meter capable of reading AMPS and place it on the incoming power lead to the air handler. If you read amps in excess of 2.0 the heater is engaging. It could be a bad thermostat or a bad heat relay.
If you read 2.0 amps or less it is a bad thermostat.
Sep 22, 2009 | Carrier Heating & Cooling
Honeywell chronotherm IV Plus thermostat
There are no batteries on an 8600-8601-8602 series
Feb 17, 2008 | Heating & Cooling
Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
1,565 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
