Question about Kenmore 80809 Microwave Oven
Turnaround glass tray problem
I am having trouble with my Kenmore Elite Microhood with model# 72180802. The microhood is functioning fine, but the glass tray pops off the lever that holds it every once in a while. This is the microhood that has one plastic tray in between the glass tray and the turnaround lever. I tried to adjust the height of that lever and realign everything, but nothing worked. I think every time the glass switches turning from one side to another, the tray slides off the circular plastic knob that slides in the glass groove. Help is greatly appreciated. Shubh...
  • KenlessElite Feb 12, 2008
    I have the same problem. Does your brown arm change directions sometimes or go in complete circles? Mine works if I manually align the arm to the front/center and the tray centered left-right. Still comes off-track eventually though. Good luck.
  • 4 Answers
Take your round glass tray and plastic three wheeled hoop to a local Sears store, open up the microwaves on display, find the one that is still using something similar, deftly trade out yours for theirs. The new wheeled plastic hoop wheels are slightly bigger and the glass tray raised guides are a bit longer, since the switch no problems like I had. Don't get caught. They do not have those parts for sale at the local Sears store.
Posted on Feb 26, 2009
  • Kenmore Master
  • 9,149 Answers
Sometimes they get heated up and bend up in the middle so they don't make good contact with the coupler. The way I fix this is to heat the support over a stove flame, then place a heavy weight on it so it holds the legs up in place a bit until it cools. Here it is step by step: 1. Apply heat at points where each legs meet the hub (stove flame) 2. Place end of each leg on an object so that the bottom of the hub is held up about 1/8" off the work surface. 3. Place heavy object on hub so the bottom touches the work surface. 4. Let it cool. 5. Test it. 6. If it still does not work, increase the height of objects in step two. See: http://207.234.249.73/mwd/turntable_support_fix.gif
Posted on Mar 26, 2007
2 Suggested Answers
kenpucket16
SOURCE: Kenmore microhood model 721.80833500
our tray that goes around and back and forth jumps the tracks and stops and turns the other way I can put it back on track before it makes a round it jumps the tracks again and starts going the other way is there a part that need replaced
Posted on Mar 19, 2013
We just hooked up the hood fan and was wondering if it was normal that when you run the microwave the hood fan cuts in?
I do believe that is the normal way to get rid of the heat and any moisture while the micro is operating .
Aug 28, 2015 | Kenmore Elite Over The Range Microhood...
What does F-7 error code on Kenmore Elite microwave mean
That's a problem with the inverter or another high voltage part.
Dec 24, 2012 | Kenmore Elite Over The Range Microhood...
Just need to re set the clock
Barbara, Google the model number with "manual" to locate (if you do not have it) the book.
Or, contact the customer service for this unit--I am sure with the recent time change they are getting a lot of calls.
Nov 08, 2012 | Kenmore Elite Over The Range Microhood...
Kenmore Microhood not working
I think it may be an internal fuse or a fusible link. You also have a series of contacts and switches inside that are set in place by the mfr. for safety. You could get it repaired for 50-75 dollars or a new one for 125-150 dollars. If you have checked the internal fuse, then just get a new one if the other one is older than 3-4 years.
Jan 11, 2009 | Microwave Ovens
Kenmore elite ultrawave microhood combination error code F9
F9 is normally a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 22, 2008 | Kenmore Microwave Ovens
Jan 13, 2008 | Kenmore 80809 Microwave Oven
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Microhood turntable not working
You can find an exploded view of your microwave at http://www3.sears.com (yes, the 3 is there). Ref # 3009 on the drawing is the turntable motor. I would grab it by the shaft and gently try to turn it. If it's locked up or grinding, that's a sign it's bad. It runs $24.49 plus shipping: Part Description: Quantity: Part Number: Model Number: Price: TT MOTOR 6549W1S013D 721.64663300 $ 24.49 $ 24.49 Be sure to unplug the oven before you work on it. Hope this helps!
Dec 01, 2006 | Kenmore 63763 Microwave Oven
Stainless Steel Kenmore Elite 36 in. 2.0 cu. ft. Microhood Combination Model 63763
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board. You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble. BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly). Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further. It may be corrupted ROM in the control unit. But let us know what you find out. - online they call me "William E. Miller, AS-EET"
Oct 15, 2006 | Kenmore 63763 Microwave Oven
Kenmore 80809 Microwave Oven Logo
152 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
