Question about Magic Chef CGR3725 Gas Kitchen Range
Can't turn on Magic Chef oven
When I push the "oven temp" button the display says "door". Can't use the oven at all. The only thing that does work is the self cleaning process. What can I do to remove "door" from display so I can use the oven again?
  • Anonymous Dec 09, 2008
    Magic Chef CGR1110ADW oven will not come on
  • 770 Answers
Check the door latch it must be opened completely if not then it will display DOOR if it is open all the way then checkthe switch on the latch assby for proper operation
Posted on Aug 06, 2008
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
Our magic chef oven will not turn on .. when we press the oven button we get a message that says locked and we cannot program the oven temperature
What model do you have? Some control panels have a control lock out button on the panels and all you have to do is push and hold the button. With a model number I can help you as to which button you need to push.
Get back to me
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 30, 2011 | Magic Chef Kitchen Ranges
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2010 | Magic Chef Kitchen Ranges
Magic Chef oven displays F3 everytime the bake or broil button is pushed. Not sure what the model # is. Electrical range.
this could be a an open probe or shorted probe connection.you need to check your temp probe harness to your main board.
there is a chance that you need to replace your temp probe.
last thing would be to replace the EOC
Feb 12, 2010 | Magic Chef Ovens
My Magic Chef Microwave is unresponsive and the display says "loc"
My magic chef is not working But when we open the door light is flash
Aug 12, 2009 | Magic Chef Microwave Ovens
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
Apr 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas oven alarming and flashing F8
Hi wlfwoman2002,
The F8 failure code description is an Analog / Digital problem. To resove this error code, please replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using Fixya.
Jan 01, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven wont regulate temp
is your temp control operated by a knob or push button?
Nov 22, 2007 | Kitchen Ranges
Magic Chef CGR3725 Gas Kitchen Range Logo
274 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
