Question about Logitech Cordless Desktop S 510
Mouse causes screen to jump to previous screen
When I use my Logitech laser mouse, the screen keeps jumping back to the previous screen. I cannot open my files or check my email because it keeps jumping back to the previous screen. This problem just started today.
  • 624 Answers
SOURCE: jumping mouse cursor
Elsamma, If you are positive keeping the cable stationary prevents the problem try this: Try holding the mouse connector stationary and wiggle the cable. If the problem occurs then the connection between the mouse connector/cable is defective, due to the low value of this mouse the fix would typically be replacing rather than repair. If that doesn?t work try wiggling the mouse connector where it plugs into the PC. If this causes the problem to reappear then either your mouse connector or the PC socket is damaged. Try another mouse and if the problem goes away, again the fix would be to replace the mouse. If a new mouse doesn?t fix the problem then there is a good chance the PS2 connector is damaged. At this point I would purchase a USB mouse which should solve your problem Let us know how things go and if you need any more assistance.
Posted on Jul 11, 2007
SOURCE: laser replacement
Thank you, but I have tried it already but without result. Best regards, Nancy
Posted on Oct 08, 2007
  • 13 Answers
It may be a problem with your usb drive, try plugging it in to a different USB drive in the computer, not the keyboard. If your CPU has no free USB drives I recommend purchising a USB port extension or a USB converter. Though it would probably be cheeper just to buy a new mouse. Tell me how it works. :-)
Posted on Mar 17, 2008
SOURCE: Cursor jumps all over the screen
Try uninstalling and reinstalling the touchpad driver from device manager
Posted on Jul 28, 2008
frcs68
  • 1605 Answers
SOURCE: How do you open Logitech laser cordless mouse to replace batteries?
puhs open the logo area (palm area), toward the backend. it takes 2 aaa battery.
Posted on Nov 06, 2008
How do i fix keystrokes that jump backward as I type?
Some Lenovo touchpads are over sensitive and they cause the cusor to slip or jump around. In Control Panel select Mouse or Touchpad. A box will open and you can locate touchpad Properties and adjust the sensitivity. Lenovo also has updated touchpad software/drivers for one or two of the most troublesome models. i was able to reduce the cursor jumping around quite a bit by adjusting the sensitivity, but i still don't think it's a good design.
Aug 12, 2014 | Lenovo Computers & Internet
My curser jumps around when I try to use my laser mouse. I changed batteries and mousepad. Is there a way to clean the inside of the mouse? I wiped the outside with a damp cloth but it is still hard to...
are you using a mouse mat or an uneven surface?
Laser Mice are renowned for jumping all over the place if the surface it runs over is even slightly uneven
Apr 09, 2010 | Logitech Cordless Mouse
My mouse (whireless) keeps jumping when i try to drag click items
It might be the surface you're using the mouse on.  Some laser mice are more prone to this than others...you want something flat with a uniform texture:
Bad:
Newspaper/magazine
Woodgrain
White formica
Good:
Proper mouse mat
Neoprene
Cork flooring
Plain material
Hope that helped.
Please rate me if you found this useful.  Thanks.
Mar 08, 2010 | Logitech Cordless Mouse
I am using my mouse then all of a sudden it jumps to a corner of the screen and wont move for a couple seconds even when i try to move my mouse. It is a logitech mouse and is a couple years old any ideas?
Your mouse is jumping, it got an itchy thing on it. By the
way, just try to blow strong over the opening of the laser eye at the bottom of your mouse. It has an accumulated
dust. We are trying to take the dust off. See if this work,
and let us know by e mail.
Oct 09, 2009 | Logitech Cordless Mouse
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
Laser mouse scrolls off screen
try the mouse without any logitech software installed for it if it keeps scrolling out of control check your mouse settings in control panel. go scroll and select the scroll to lines 5 or less. see if that changes anything.
Jul 14, 2009 | Logitech MX1000 Laser Cordless...
The cursor on my mouse is jumping all over the place, and I can't control it. How can I open the back of my mouse, so that I can clean the ball any thing else in the mouse. I have a Logitech M-S69.
there should be a circle ring around with arrows. Twist it so it opens. Then the ball will fall out. There are 3 places grims will build up. Get some tweezers and pull that stuff off.
You should probably get a laser mouse. I am sure amazon has them for a couple bucks.
Dec 02, 2008 | Computers & Internet
My mx1000 likes the corner of the screen
Check the batteries. Try changing them to see if this resolves the problem.
Ensure that you have a good surface for the mouse to travel on and make sure that the receiver for the mouse hasn't fallen down the back of your desk etc as this will cause the cursor to jump around the screen.
Hope this helps
Please rate my solution
Thanks
Jun 17, 2008 | Logitech MX1000 Laser Cordless...
Dec 03, 2007 | Logitech Wireless Access Duo Optical...
Jumping mouse cursor
Jul 11, 2007 | Logitech -9536890403 Mouse
Computers & Internet Logo
113 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
