Question about Labtec Mini Wireless Optical Mouse 911531-0403
I Have just bought A mini wireless mouse which does not work.The light is not coming on the USB stick and the cursor does not move
  • ramosrich May 11, 2010
    greetings.
    when you bought this, it comes with a cd installer. try to install the cd and see if it works.
    Problem Solver:
  • 6 Answers
Push the sync button on the bottom of the mouse an restart the computer
Posted on Jan 12, 2010
How do I get the mouse to mouse the mouse cursor
the battery in the mouse makes the red light come on, not the operating system.
Look in Device manager,find the mouse, uninstall the drivers, scan for new devices, re-install the drivers.
Otherwise look for new drivers on manufacturers site.
Apr 13, 2014 | GE 98566 98566 wireless optical mini mouse
How do I connect a microsoft wireless moblie mouse 3000 to my laptop?
Press the button on the back of the mouse to free the battery cover on top.
Remove the battery cover and put the supplied AA battery into the mouse.
Replace the battery cover.
Insert the wireless USB dongle into a USB port on the laptop or desktop computer.
Move the mouse and watch your computer screen.
Confirm that the mouse is connected by making the cursor move.
Hope this helps
Sep 26, 2012 | Microsoft Wireless Mobile Mouse 3000
Targus Model PAWM002 optical mouse will not work. When I plug the stick in the red light comes on and I have replaced the batteries in the mouse. Turned the switch on the underside of the mouse on and the...
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps dont forget to vote
Feb 28, 2011 | Targus Wireless Mini Optical Mouse
I have a Mini Wireless Optical Mouse. M/N M-RAD92. I just changed batteries. The mouse is lit up, but the USB port stick's light will not light up and the mouse is no longer worker.
usb stick doesn t light also on mine but works perfectly. press once on stick button and once on mouse "setup" button and they will connect.
Jan 31, 2011 | Labtec Wireless Desktop Keyboard/Mouse...
My mouse cursor will not move on the screen when I try to use my new wireless mouse. The light comes on on the bottom of the mouse and the USB is plugged into the computer. The USB blinks red when plugged...
Hello, hope this isn't a silly suggestion, but have you pressed the 'connect' buttons on the mouse and receiver so that the 2 devices can synchronize?
Regards,
nicam49
Dec 29, 2010 | GE Wireless Optical Mouse
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
Fairly new mouse (new batteries also)not working. Solid blue light when plugged into USB port but cursor will not move at all when click mouse buttons or scroll bar. Rebooting system nor unplugging USB...
First make sure your mouse is installed properly. Go to Device Manager and see if it lists the mouse and has no conflicts. Also, try a different USB port, especially if it doesn't show up. If your receiver and mouse have reset or connect buttons on them you'll need to push those also. try alternate batteries. if none of these suggestions can solve your problem you may be looking at a defective mouse.
Nov 05, 2009 | GE Optical Mini Wireless Mouse 98793
The cursor on my laser wireless mouse won't move
You need to sync the mouse with the USB receiver. They'll be a similar button on the receiver. Push both at the same time.
Apr 07, 2009 | HP Wireless Optical Mouse
GE Wireless Mini Mouse 97985
Press the link button on the receiver the indicator light should start blinking. Then within two seconds press the link button on the bottom of the mouse, the indicator light should quit blinking. After re-linking the devices move the mouse to see if it moves the cursor. If the cursor does not move, then move the mouse and see if the indicator light on the receiver blinks. If the device does not blink then try re-linking the devices again.
Jan 31, 2008 | GE 97985 Mouse
MAC wireless mouse does not move cursor
Have you tried in safe mode?
Please check in safe mode, If the mice works then re-install os by selecting archieve and install.
Make sure to select the preserve user data tab while performing re-installation.
Dec 14, 2007 | Apple Mac mini G4 Desktop
Labtec Mini Wireless Optical Mouse 911531-0403 Logo
226 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
