Question about Whirlpool GS460 Gas Kitchen Range
The oven will not stay up to temperature
The over works sometimes but for things like cooking a turkey or baking a pie it will not maintain the temperature setting. What do I do?
This range has Direct Spark Ignition System (DSI). If ground is lost or not present on the DSI board (located to right of the display board when looking at the rear), the DSI will not detect the flame. The easiest way to determine if this is what is happening is by listening for the flame to start. If you hear a woosh (flame starting) but still hear the sparking, the DSI system is not detecting the flame. It will re-try three times then lock the system out (there will be no indication on the front panel) and will need to stop the bake cycle and re-start.
To fix, remove the top panel in the back and use an ohmmeter to measure the ground from the DSI board (upper right board) to the ground pin of the power plug. I would recommend placing a starlock washer on all the grounds to prevent this from happening.
For more information see: http://appliancehelp.hypermart.net/DSI_manual.pdf
Posted on Dec 30, 2008
Why do I have trouble getting my Marie Callendar's fruit pies to set up? Is there a tip?
I'm not sure what you mean by 'set up', but are you cooking them while they are still frozen? I believe that's what it says on the package. If you follow their directions, you should have no problems. Also, is your oven temperature correct? Sometimes when you set it at 350, it's really hotter or colder, so I would check that, too. You can buy a temp gauge at the store, they're not all that expensive. Also, after baking, let the pie sit out for about an hour to firm up.
Oct 08, 2017 | Cooking
How long do i cook a 13 lb. turkey and at what oven temperature
What temperature do you cook a 13 pound turkey at?
After about 3 hours, insert an oven-safe thermometer deep into the thigh without touching the bone. Begin checking the turkey for doneness about 30 minutes before the recommended cook time. Your turkey is done when the temperature with a meat thermometer is 180┬░ F in thigh and 165┬░ F in middle or stuffing.
How To Roast a Turkey ' Butterball®
www.butterball.com/how-tos/roast-a-turkey Search for: What temperature do you cook a 13 pound turkey at?
Nov 20, 2016 | Kitchen Appliances - Others
How do I bake a frozen fruit pie that has thawed
Preheat your oven to 25 degrees lower than the package says. Then take a long strip of foil and cover just the edges of the pie( like a halo). The thawed edges will bake so much faster than the rest of the pie. Then bake it as usual. Just check it every 20 minutes or so. Everyone's oven is different.
Jul 30, 2014 | Marie Callender's cherry pie, famous flaky...
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
I AM COOKING MY TURKEY AND AN F10CODE COMES UP CAN I CONTINUE OR WHAT
F10 on Kenmore ovens means Runaway temperature error, it means that the probe sensor detected overheating.
Stop the oven and allow cooling for one hour or so, with the power cord unplugged.
If error is still there, then you will need to call the technician and have parts below checked and eventually replaced.
http://www3.sears.com/imaging/ImageP...&titleID=00003
Part#316217001
About the turkey, see if you can borrow one of your neighbour's oven to finish cooking, or leave it half baked and put it back into the oven if the oven restart after cooling up. Remember that you will need to add some more time to the total cooking time, as the turkey will get cold inside.
Good luckshow?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
Nov 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
16Qt Roaster oven
Dear Lunders
I cannot recommend cooking a turkey in a crockpot for many reasons. I have always cooked turkeys at 200/225 degrees in the oven overnight. The secret is to seal the roaster with heavy duty foil with maybe a cup of water in the roaster, bake the bird upside down. Turn it over, increase the temperature, and uncover it for an hour before serving. Worked for me for 40 years, and the guests never complained.
Ray
Nov 27, 2008 | Crock Pots & Slow Cookers
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Whirlpool GS460 Gas Kitchen Range Logo
142 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
