Question about Kenmore 47772/47774/47779 Electric Double Oven
Am getting the message F2 and the oven is beeping
I pressed "clean" for both ovens; the top oven appeared to start, but the bottom one did not. As I was attempting to figure out the problem, I must have pressed a button to stop the cleaning in the top oven; then the "F2" message appeared, and the oven started to beep.A couple of questions: 1. How do I get the beeping to stop? 2. What does F2 mean? 3. Can I clean both ovens at once? I cannot find my manual so have nothing to refer to.....
I bought this double oven around 1999/2000 and am not sure of the model. If you can help me figure this out, I could find the manual online and print that out.
Help! Sandy Forster
  • 3 more comments
  • sandoster Dec 17, 2008
    I don't have access to where it plugs in. Any other ideas? :)
  • Toria Dorsey
    Toria Dorsey May 13, 2014
    My problem is the F2 beeping is driving me crazy and i'am not trying to clean my oven it just started doing this. I simply just want to know where is the unplug cord. I have an appointment for someone to come out but the beeping is driving me crazy. It seem like my oven is built around my cabinets and I can't figure out how to pull it out or unplug it HELP!!!!!
  • Toria Dorsey
    The only thing I want to know is how to unplug my GE oven. It's a 1990 model and seem like it's built around my cabinets and hard to pull out. I simply want to know how
  • Toria Dorsey
  • Toria Dorsey
  • 3 Answers
Unplug it for a few minutes
Posted on Dec 17, 2008
  • BUG0903 Dec 17, 2008
    USUALLY F2 MEANS A POWER PROBLEM AND IF YOU CAN DISCONNECT THE POWER, THAT SHOULD FIX IT. GET ME THE NAME OF THE APPLIANCE.
  • Toria Dorsey
    The only thing I know is its a GE oven. The microwave is not attached to it but it's one above it.
I get the error code FSE1, lock won't engage message for the bottom oven everytime I turn on the top or bottom unit. The message will not go away until I turn the top unit off. The bottom lock keeps...
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 19, 2011 | KitchenAid Architect KEBS208S Electric...
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
F2 Beeping!!!!
F2 Oven too hot Replace oven temperature sensor
Mar 09, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
PROBLEMS WITH FR ERROR MESSAGE APPEARING
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
Dec 14, 2006 | Dacor ECS230 Epicure Stainless Steel...
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 47772/47774/47779 Electric Double Oven Logo
269 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
