Question about Samsung SGH-i450 Cellular Phone
Slider Problem i have problem in opening slider. suggest me appropriate reasult....
  • 2 more comments
  • chirayu_dalw Dec 18, 2008
    ya i think belt problem
    means i have problem in sliding it up and down
    else it is working fine....
  • chirayu_dalw Dec 19, 2008
    then what is the solution for that????
    ya i have warranty.... n i stay in india.... will it be the part of warranty????
  • Kenny Gabriel
    Kenny Gabriel May 11, 2010
    Do you mean you have an issue when the slider is opened? Only slider phones there is usually a little bar in between the screen and the keypad that helps you to slide the device up. If you meant you have an issue with the device actually responding to the slide, there could be a setting that you have on your device which enables the device to go to the home screen when slid up. What other issues are you having???
    Scholar:
  • 59 Answers
The belt isn't having an issue because that is connected to the belt... you may just have a hinge issue which is what actually slides the front half of the phone up.
Posted on Dec 19, 2008
  • 68 Answers
Just change the strip i mean the belt inside it will be ok
Posted on Dec 17, 2008
Change fork oil street bob 2007
To change the oil or to rebuild a 2007 DYNA front fork FIRST raise and support the motorcycle so that the front end is off the floor and the forks are fully extended, remove the brake caliper and the front wheel, remove the front fender, loosen the pinch bolt screws, do not remove the tube caps, slide the fork sides downward clear of the fork brackets, repeat the procedure for the opposite fork tube and slider assembly.
To disassemble a 2007 DYNA front fork clamp the fork tube and slider assembly in a fork tube holder tool mounted horizontally in a vise, use a 12mm Allen wrench is needed to loosen but do not remove the seat pipe screw, while the internal components are still under tension and less prone to rotate, on the right fork tube and slider assembly, remove the axle holder to access the seat pipe screw, remove the fork tube cap and its o-ring, remove the long spring collar, remove the fork assembly from the fork tube holder tool and invert it over a suitable container to catch the fork oil and allowing thefork to drain, extend and retract the slider several times to push oil out of the internal fork components, the washer, and the spring will fall out of fork tube. THEN clamp the fork tube in the fork tube holder tool, remove the slider cover from the slider by inserting a brass drift into the notch in the slider and lightly tapping the cover loose, compress the stopper ring and remove the stopper ring from the groove in the top of the slider bore, Do not remove slider tube caps without relieving the spring preload or the caps and springs may fly out. THEN remove the seat pipe screw and its washer from the bottom of the slider and retain them for reuse, withdraw the slider from the fork tube until the bushing guide contacts the bushing on the fork tube (the bushing guide is a slight interference fit in the slider), then using the slider as a slide hammer, hit the bushing with the bushing guide with a quick continuous stroke until the slider is pulled free from the fork tube, drain the slider and allow the stop oil lock piece to fall free. (If you are only changing the oil or replacing the slider the remaining parts can be left assembled and the fork re-assembled) If it is still attached to the seat pipe remove the stop oil lock piece from the lower end of the seat pipe, remove the seat pipe piston and the ring assembly, remove the rebound spring, remove the oil seal, remove the seal spacer, and remove the bushing guide. Repeat the foregoing procedure for the opposite fork tube and slider assembly.
Thoroughly clean and inspect each part and if and as necessary replace any corroded, worn, bent, broken or otherwise damaged parts, inspect the fork tube bushing and the slider guide bushing and replace if and as required, always replace all oil seals and all o-rings, check the dust cover where it rubs on the fork tube (it should have a good and continuous seal and not show excessive wear, check the fork tube where it rubs on dust the cover and the tube should show a bright, shiny surface, free of scoring or abrasions, if any spring(s) is/are broken they must be replaced, if a fork tube or slider is bent or damaged it must also be replaced now, replace all other worn or damaged components if and as necessary.
To assemble a 2007 DYNA fork FIRST insert the seat pipe assembly with the spring into the slider tube, slide the bushing guide down to the bushing on the fork tube, follow it with the spacer, the oil seal, the stopper ring, the dust shield and the slider cover, install the fork tube into the fork tube holder tool, fit the lower stop onto the seat pipe, slide the seat pipe back into the fork tube until the seat pipe is centered in the tube, gently install the slider assembly onto the slider tube and the bushing, thread the seat pipe screw and washer into the seat pipe through the bottom of the slider assembly, draw the fastener into the seat pipe but do not tighten it at this time, verify the proper action of the fork by moving the slider up and down the fork tube, locate the appropriate fork seal driver over the fork tube in front of the oil seal with the fork seal chamfered lips facing the oil in the fork, in the following order assemble thetop oil seal, the spacer and the bushing guide into the slider bore, install the stopper ring into its groove above the oil seal, push the dust seal against the oil seal and stopper ring, rotate the slider cover to match any removal burrs to the notch in the slider and snap the slider cover into place. THEN operate the slider through its full range of travel several times to verify alignment and proper smooth operation, then pulling down on the slide to apply downward force on the rebound spring, tighten the seat pipe screw to 106-159 in-lbs (12-18 Nm), vertically re-position the fork tube into the fork tube holder tool and with the slider tube compressed, fill the fork with Harley-Davidson TYPE E FORK OIL until it is approximately the amount specified below for the type or motorcycle and fork that it is.
a. FXDWG- approximately 29.6 oz (875 cc) and distance from the top of the fork tube = 4.4 in (112 mm); and
b. All other Dyna models- approximately 26.6 oz (787 cc) and distance from the top of the fork tube = 4.3 in (110 mm)
THEN slowly pump the slider 8 to 10 times to remove air from the fork assembly and fully compress the slider to properly measure the oil level which is measured from the top of the fork tube, with the spacer and the spring removed and the fork fully compressed, then using an appropriate oil level gauge tool adjust the oil level to appropriate level for the fork type and model, pull out the slider and install the spring in the fork tube with the tightly wound end at the bottom, install the washer and the spring collar, carefully to avoid cross threading, install the fork tube cap with a new o-ring and tighten it to 16-43 ft-lbs (22-58 Nm). Repeat the process for the other fork tube and slider assembly.
To install the fork in a 2007 DYNA FIRST insert the fork tube and the slider assemblies up through the lower triple clamp and the upper triple clamp so that the fork tubes will protrude above the upper triple clamp 0.450-0.500 in. (11.4-12.7 mm) with the measurement taken at the midpoint of the fork tube between the top surface of the triple clamp and the top of the fork cap and when properly positioned tighten the pinch bolts to 30-35 ft-lbs (41- 48 Nm), install the front fender and bracket, install the front brake caliper(s), install the front wheel and align the wheel to the forks.
May 11, 2014 | 2006 Harley Davidson FXDBI Street Bob
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
J700 camera could not start if Slider already opened error comes "Open Slider"
There is an switch provided near the slider so that when you open it it activates and you can use the camera function.
When you open the slider if it doesnt activates the switch then you cannot use your camera.And it shows as 'open slider'
Please take your mobile phone to service centre they will fix this problem.
Its a very small problem
Thanx
Jul 26, 2010 | Samsung J700 Cellular Phone
My polk audio speakers from a prior hp computer are very, very quiet on my new compaq system. what can i do?
The audio setting in your new computer is set to low level. Right click on the speaker button at the right hand bottom corner of your task bar,Then open the volume control from there. push the slider up in the volume control and also on the wave.You can push the slider up for the CD player as well as PC speaker also if any of these are also kept at a low level. If you do not have a speaker icon in the task bar, open control panel,(click on start and you will see the control panel selection, double click on it) and double click on sound and audio devices. Under device volume, push the slider from low to high. while you are here you can click on "place volume icon in the task bar" You can also click "advanced" and select the appropriate speakers here, like desktop stereo speakers or surround sound or whatever suits your speaker. click ok to save this and that is it.
Jan 22, 2010 | Extech Instruments Circuit Breaker Finder,...
Only hear texts/calls if slider open
change the FLEX -The flexible cord linking the screen part with the panel
Nov 30, 2009 | Samsung SGH-U600 Cellular Phone
The desktop on my monitor is square and no-longer fits the screen, how do I turn it back to an desktop image that entirely covers the screen?
This will depend on what operating system you are using:
Win 98/ME/2000/XP/XP PRO/XP 64-bit
1. Click on the start button
2. Click on Control Panel
3. When Control Panel opens, find the Display icon and double click
4. When the display properties window opens, click on the tab towards the top labeled settings.
5. Move the slider under the option Resolution all the way to the right or desired resolution if you know it.
6. Click apply and make changes (try another resolution) if necessary.
7. Once you have found the appropriate resolution, click OK.
Win Vista
3. Double click Personalize
3. Scroll to the bottome and click Display Settings
4. Move the resolution slider to appropriate resolution
5. Click apply and make changes as necessary
6. Click Ok when done
Hope this helps!
PS - Please rate the help provided. Your time is much appreciated!
Oct 15, 2009 | Acer Computers & Internet
Removing a slider door to patio
open the slider 7/8 of the way open and lift the slider up and out of the track. you may have to get a helper as the slider is heavy. there might be little plastic clips in the top track of the door that need to be removed before lifting the slider out.
Jun 06, 2009 | Anderson Manufacturing Greg Anderson,...
All my dad's pictures are coming out blue-ish green...
open the camera; set dial to 'I'; press the up button on the menu until 'exposure' appear; press once again until 'red-blue' slider appear; move slider to left/right in order to get the colour you want.
Sep 28, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Samsung SGH-i450 Cellular Phone Logo
88 people viewed this question
Top Samsung Cell Phones Experts
John Tripp
John Tripp
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
