Useless new panasonic split air conditioners
I live in the republic of Panama; and recently moved to a new house, bought 8 new split units, regretfully panasonic.
Worst decision ever.
Any change in electricity fluctuation, and the electrical cards inside, explode.
Took the cards to their service centers ( 3 hours drive away) after 3 months got them repaired, andother eletricity fluctuation and there they go again.
How come this didn't happen with other brands of split units? all my splits are Panasonic but one which is Royal; and Royal so far so good while Panasonic is useless, my neighbour had same problem; but the Samsung units where good
bobotfel
  • 236 Answers
SOURCE: air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Posted on Dec 31, 2007
SOURCE: Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Posted on Jan 13, 2008
  • 147 Answers
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
TheMazz
  • 78 Answers
SOURCE: Looking for Panasonic split air conditioner manual
Click on this link to find your manual:
http://www.panasonic.com/CONSUMER_ELECTRONICS/bp_split_ac/support.asp
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Posted on Oct 15, 2009
Testimonial: "Thanks a lot!"
SOURCE: I have a Panasonic split
I have a A C Panasonic, I m operate with remote bat not communicate, and than b emergency switch. indoor unit "on" but out door unit doesn't running. what wrong?
Posted on Jun 10, 2010
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
My panasonic air conditioner does not turn off when cooling
At what temperature is the thermostat?
The temperature should never be lower than 70?F (21?C) for the unit to operate properly. If your temperature setting is above 70?F, then your unit might have a problem with the temperature sensor that controls the "on/off" cycle on your unit. For that you will need a professional certified HVAC tech to inspect it.
Most people think that lowering the temperature to the minimum will cool the room faster, but that is not the case. Since HVAC units move the air at a specific rate, it can only transfer the temperature, thus cooling/heating the air, within those parameters. That's what the calculation for the BTU is for. Normally cooling/heating the room to the desired temperature should take about 1 hour, but some new inverter units can do it in only 30 minutes or so. Lowering the temperature constantly or even keeping it at the lowest setting may cause premature failure of the unit.
Aug 04, 2014 | Panasonic 36PEF1U6 31,200 BTU Single Zone...
We bought a house with this unit in it and there is no manual. Would it be possible to get the manual on line or sent to me?
The owners manual is really pretty useless. Mostly common sense safety warnings. If you have questions how to maintain or service the unit, just ask. Sadly, replacement parts dont seem to be available anymore as the company is out of business.
Aug 01, 2011 | Windchaser PAC9 Air Conditioner
Do split air condition need good ventilation
Well if your asking that if it needs a good ventilation? Yes.
Some things to consider when moving the compressor unit.
1. Length of the tube to be added ( for coolant).
2. Maintenance space.
3. Ventilation
4. Some liquid to be taken care of or gas.
5. Drain water.
For additional inputs. Aircon basic set up is exchanger. On the other side it collects hot air then flush it on the other side which is the condenser that is using fan to flush add added temperature.
Sep 17, 2009 | Heating & Cooling
English Instruction Manual for a Toyo TA-09CHS Split Air Con Unit
I bought two TOYO split air conditioner in 2009. They are awesome, the best quality split air conditioner in Japan. I have two manual in English and I can mail you one. Please let me know how to mail it to you.
Jul 20, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Mini Split Condensation Problems!
Maybe you need to invest in a good De-Humidifier.
Jul 08, 2009 | LG LS-L1210CL Mini Split Air Conditioner
No Instruction manual
This is for APAC
corp.carrier.com.au/content.cfm?content=111 -
This is for; Hotpoint
://www.geappliances.com/service_and_support/literature/
May 28, 2009 | Heating & Cooling
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
