Question about Agere FM56 / 56k -V. 92 (Lucent) PCI Soft Modem I-305 (Retail) NO VOICE (I306)
Agere pci modem doesn't catch the line for receiving faxes
Under XP pro, recent driver oct 2007, the outward fax works fine, but it lets the line ring in receive mode. It works once in a while only. The settings of my fax software (XP fax or snappy) are correct. The modem is queried fine. Is there a specific command line to send to the modem ? Is it a known problem ?
Thanks in advance
  • Agere Master
  • 17,818 Answers
When it is being called, from a command line issue AT A or AT A0 and see if it answers/
Posted on Oct 29, 2017
Fixitman909
  • 430 Answers
SOURCE: MODEM ON HOLD-
is pc showing this modem in control panel under system icon? now try uninstalling Modem and reconnecting it and plug in phone line......if software cant detect it on boot up ...then it sounds like a defective modem.....
Posted on Jun 11, 2009
jeevan.m
  • 392 Answers
SOURCE: error keeps saying
install the modem drivers properly
Posted on Aug 31, 2009
  • 10 Answers
SOURCE: Agere Win Modem Driver Version 8.30.0.0 vs V.92
you have a v.92 modem even if it lists as v 90 just run a windows update,, look for hardware updates, , if none comes up for the modem you should be good .
the last update was to 8.30 for v92. .. v90 etc. . it wont make that much of a difference in speed. .. however
A phone line filter WILL make an amazing difference, having worked for a dial up isp before , trust me , they help alot. .. its worth 12-22 dollars from any radio shack or maybe even walmart.. . i've seen them in home depot as well but don't spend more than 25 dollars. .
"phone line filter" look for it on radio shacks website
http://www.radioshack.com/product/index.jsp?productId=2103593&numProdsPerPage=60&retainProdsInSession=1
the picture is accurate.. not sure of the description, that thing is not for two lines.. its a a single male end --- to --- female end filter no bigger than a permanent marker. .
good luck. . oh.. it should increase performance from say 34k to 48/56k orn your modem. .
good luck. . its the next best thing to having new lines put in... to your house.
or usb broadband from cricket.
Posted on Nov 17, 2009
  • 10 Answers
SOURCE: i have an agere win modem com 3 installed.my modem
try using a different dirver, , ..
http://download.cnet.com/AOpen-FM56-SV-Soft-PCI-Modem/3000-2109_4-71965.html
  • 476 Answers
SOURCE: win xp pro reconize my agere modem but it
as long as your logged on as administrator then updating your device should be straight forward,
so plug in your card
start up your computer
the wizard should pick up the new device and autoinstall it
then update your drivers for the device or download the drivers from the manufactuerers web site
check your model and make of device
Rate me please MISTERDJ
Posted on Apr 10, 2010
Testimonial: "I'm really thank you for your advice, I'll try it right away, there's no doubt that it works."
Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Dec 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
(agere sv92p too)How to get this fax modem driver for xp?
I was looking for the same driver and came across you needing it too. This driver does work I linked to does work. I just used it on xp sp3. If by some chance you cannot get it to work, just look for 'lucent sv92p' as Lucent and Agere are the same company.
http://members.driverguide.com/driver/detail.php?driverid=123626
You will either need a free membership or look at 4 or 5 pages of ads to download this driver. Sorry, but I could not find it at any other sites that did not require a membership.
Apr 15, 2009 | Aztech MDP7800U Agere 1648C-TV5 56K PCI...
How fax work in DFM-560EL
my windows XP detect my PCI smart link modem
but can't find the driver for it
Oct 28, 2008 | Computers & Internet
I can't send to certain fax machines with WinFax Pro
Yes, some modems might have problems with Service Pack 3. You might need to update the Windows modem drivers.
Alternatively, there might be problems with the settings in WinFax for your specific modem.
You'll need to post more information on the fax modem you are using.
http://www.getfaxing.com/forums
Jul 28, 2008 | Symantec WinFax Pro for PC
Fax modem
DRIVERS FOR FAX MODEM MOTOROLA SM56 WITH XP
Jun 22, 2008 | Arris SM56 (SM-56-PCI) Modem
Re initializing a data/Voice Modem
Go to start,control panel,hardware device and see if your moderm is still there. If so, right click on top of the moderm uninstalled. Turn the computer off and back on. At this time, it should come back on and look for the modem.Answer yes to found new modem and reinstall the modem. this should work
please check you modem setting. it could be that your setting also is not correct.good luck
john
May 27, 2008 | Computers & Internet
Winfax pro suddenly faxing to wrong number
you have some options, so choose one.
  1. remove your fax
  2. configure your fax to answer later (maybe after ringing 10 times) and configure the winfax to answer before (something like ringing 5 times or less)
the problem here is that the fax answer and start receiving the fax and the winfax receive the fax signal at same time. check the winfax maybe you have the half part that the fax modem not has printed stored in winfax, maybe.
as I said, your better choice is removing the fax modem. even configuring like I said before, maybe the two continue to try to receive the fax at same time.
hope it helps.
Dec 13, 2007 | Symantec WinFax Pro for PC
Computers & Internet Logo
110 people viewed this question
Top Agere Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Agere Computer and Internet Expert? Answer questions, earn points and help others
