Question about Memorex Karaoke System MKS5620RFB
When I press the power, screen comes on, it will not play.
I have a Memorex Karaoke machine, Press power button, screen comes on but it will not play a disc nor cassette. There is a small light beside the power button but it does not come on either. What could be wrong?
2 Suggested Answers
SOURCE: I have a Memorex Karaoke machine, Press power
Had same problem opened up back found blown fuse replaced and still blows.
Unhooked power source from were fuse was blown and fuse dose not blow seems to be something in that big board above it.I'm realy not into repairing of electronic boards. There is a lot or stuff going on inside there.
Just thought I would share my experience.
Good luck
Posted on Nov 24, 2009
Can i hook up my ipod using a usb cord?
Won't play ITunes! This Karaoke is incompatible for Apple (ITUNES, IPOD, etc.) I even tried creating Thumb Drive (using USB) and then a CD. This brand Karaoke won't play the ITUNES songs.
:((( Very frustrated
May 22, 2013 | Memorex MKS8594GP Karaoke
My karaoke machine will not play CDs
the only suggestion I can offer is clean the laser lens with a Q-Tip and rubbing alcohol gently and allow several minutes to dry, if that fails! the whole assembly will need to be replaced.
Mar 15, 2012 | Venturer CD-2160 Shelf System
I would like to play karaoke songs from mp3 player through the karaoke machine but donnt know how
instructions for this can be found on the user manual
http://dl.owneriq.net/d/d7412619-cea1-4119-965a-e343e67cb81f.pdf
that is a link to your manual.
If your player has these functions and your user manual doenst have the instructions its maybe cause your model doesnt support it. you may need to contact the manufacturer for details regarding this.
I cant be certin as I dont own that particular model nor do i have experience with that model. If you have a microphone jack then the chances are it supports it.
In most players with this feature there is a karaoke setting and a button on the remote to access it. in some players you will need to access it through the menu button on the remote or karaoke button. Its different in all players.
Feb 27, 2010 | Memorex MVD2022 DVD Player
I have a Memorex Karaoke machine, Press power button, screen comes on but it will not play a disc nor cassette. There is a small light beside the power button but it does not come on either. What could be...
Good luck
Oct 20, 2009 | Memorex Karaoke System MKS5620RFB
Cd does not play when inserted. We cleaned the lens with a lens cleaner.
The optical lens assembly is damaged at this point. the lens has burned out and the tracking/load motor seems to be faulty as well. replace the optical lens asap.
Jun 02, 2009 | Sony Audio Players & Recorders
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
Picture rolls on the screen
your tv had no problem, use the remote of your karaoke machine and press the system. your karaoke machine was set on PAL change it to NTEC or press N/P
Sep 27, 2008 | Orion1934 19" TV
MEMOREX KARAOKE MKS8503
When I press the power button, it will not work at all. It won't play a disc and the screen won't show that it is on either.
Aug 26, 2008 | Memorex Karaoke System MKS5620RFB
Memorex MMP8565 (1Gb MP3 wont work
This screen has a sleeper function to save power - this is normal - any key should wake it up
Feb 21, 2008 | Memorex MMP8565 MP3 Player
41 people viewed this question
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
