After recent wobble, I reloaded new firmware,but when I tried run use the box nothing happened. All I got was "0" on the front panel.
Can I unlock it, & what firmware should I reload.
This I am sure is a software problem not a hard ware problem.
When I switch on the dotted line come on, then the display just shows "0".
Neither the remote or pressing any of the buttons on the genuine Starview work.
I have tried to reload old software but it will not reload.
Any further thoughts?
Thanks
Derrick TimmsThanks for the info, but none of it helped.
I have the same problem. I updated the box and then all I get is 0. Tried old update but that did not work and can't access menus and also tried buttons on box but to no avail.I have the same problem. I updated the box and then all I get is 0. Tried old update but that did not work and can't access menus and also tried buttons on box but to no avail.
You can't post conmments that contain an email address.
did you flash with the correct firmware take it out make sure you have the latest firmware if you have factory reset the box then reload the correct firmware make sure your box is not a clone if it is then put the clone firmware on or this will brick the box
You are wasting your time asking for codes here or anywhere else for that matter. The codes are being changed that often recently that you just wouldn't be able to keep up.
If you have the starview superusb new firmware is available. If you are in the UK you will need to rescan your box as a lot of frequencies have been changed the firmware you have will still update. For Ireland the encryption has changed and the ONLY firmware out yet is for the Starview superusb.
I also have a starview box 2 with an NTL connection/ When i put the codes in for example 00 - cd 76 82 bb 22 0a then i press ok then i enter 01 - 35 5e d6 40 6e aa 99 41 then go to channels i get updating data and it stays at 0%. Why ?? What a nightmare !! Can u help !?
Thanks
Derrick Timms
