Bad Power Supply.
Weak Voltage power rail. Enough power to light those two LED lights, but not enough power for the Processor.
Be nice if I knew the computer manufacturer name, and the Model Number.
A) When the computer's Power Supply is plugged into power, there is a 5 Volt Standby power present for the Power Supply.
This 5 Volt Standby power is what activates, (Turns on) the Power Supply, when you press the Power On button.
(The Power On switch located within the plastic Power On button, is a Momentary Contact Switch)
Power Supply activates, sends power to the motherboard.
(That LED light on the motherboard, indicates the motherboard is receiving power. Has nothing to do with the CMOS battery located on the motherboard)
The first chip to receive power is the BIOS chip.
(Chip and Chipset are slang terms for I.C.
Integrated Circuit
http://en.wikipedia.org/wiki/Integrated_Circuit )
Power to the BIOS chip initializes the BIOS program, which is burned into the chip.
BIOS (program) looks to see what devices are installed, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the O/S.
(O/S. Operating System. Windows XP is one example of an O/S)
1) ALL the LED lights use less than 1 Watt of power.
To include the Power On LED, the LED on the motherboard, and the LED light on the Power Supply.
2) EACH fan uses 2 to 3 Watts. So if you see any fans spinning, (Then stop of course), they don't use squat for power.
3) A typical Processor uses 51 to 125 Watts. (Less for older Processors such as the Intel Pentium III's, and what have you)
So you are getting power, right up to the point that BIOS goes to turn the Processor on, then there isn't enough power to turn the Processor on, or keep it on.
Bad Power Supply.
The SMPS (Switched-Mode Power Supply) in your computer produces three main Voltages.
A) 3.3 Volts (3 point 3)
B) 5 Volts
C) 12 Volts
[All are DC voltage.
Two D cell flashlight batteries produce 3 Volts DC ]
http://en.wikipedia.org/wiki/Switched-mode_power_supplyWires that have Orange insulation on them are 3.3 Volt wires.
Red wires are 5 Volts
Yellow wires are 12 Volts.
You will see many wires in the cables inside the computer, that carry these colors.
All of these wires terminate inside the power supply.
EACH Voltage terminates in One terminal point within the circuitry of the Power Supply.
The 3.3 Volt wires terminate in one central point, in the circuitry within the Power Supply.
This is the 3.3 Volt power rail.
The 5 Volt wires, and 12 Volt wires follow suit.
There is a 5 Volt power rail, and a 12 Volt power rail.
Hence the term Power Rail, and my reference above to - Weak Voltage power rail.
The power rail to be most concerned with when testing a Power Supply, is the 12 Volt power rail.
You can test it with an economical multimeter, (Translates to cheap), or an economical power supply tester.
Economical multimeter's run from $5 to $12.
Found in a variety of stores. An auto parts store may be one avenue of approach, and perhaps Radio Shack. (Not advertising for Radio Shack)
This is one example of a power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471Power Supply unplugged from power, the Positive (Red) probe lead of the multimeter, is connected to any Yellow wire.
I attach an alligator clip to the probe lead, and clip it to a metal terminal at the end of a Yellow wire.
The Negative (Black) probe lead is connected to a Ground wire.
ANY wire that has Black insulation on it, is a Ground wire.
Then plug the Power Supply into power, press the Power On button, observe what Voltage is present.
11 to 13 Volts indicates the Power Supply is fine.\
Less than 11 Volts means it's time to replace the Power Supply.
[NOTE*
Should state.
BEFORE you reach inside your open computer case to test the 12 Volt power rail, the computer should be unplugged from power.
You should also observe Anti-Static precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
You may not even see it, or feel it.
Computer unplugged from power, computer case open, TOUCH the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle, while working on it, upon your return Touch the metal frame again.
Or use a $6 ESD wrist strap, and connect the alligator clip to the metal frame.
(Electro Static Discharge)
Or, you can use a KNOWN to be good, Compatible power supply for a test unit.
It has to be KNOWN to be good, or you will be right back to where you are now.
Compatible:
Has to have the correct power cables, and has to have at least the minimum amount, of power cables needed.
Extra power cables can be tied up out of the way. (Use plastic ties, not paper wrapped metal, bread ties)
Reference to power cables, and their respective connectors, used in personal computers,
http://www.playtool.com/pages/psuconnectors/connectors.html[There are those who may have a computer that is unused, and sitting around.
Has been replaced by a newer computer, or what have you.
The Power Supply could be borrowed for the test, then returned to the donor computer.
IF, the Power Supply is KNOWN to be good, and Compatible.
Just food for thought ]
DO NOT open a Power Supply, and attempt to repair it!
Inside the Power Supply are various hardware components.
Some of these components are Electrolytic Capacitors.
[One's used in Power Supply's at present, {To my knowledge}, are Radial Aluminum Electrolytic Capacitors,
http://en.wikipedia.org/wiki/Electrolytic_capacitor ]
The basic operation of a Capacitor is to slowly build up a charge, then release it all at once.
Think of a large swimming pool being filled up by a garden hose, then when full, one side of the pool is taken down all at once.
IF, your finger/s touch the terminals on the bottom of a charged capacitor, the charge can be released to You!
IF, your finger/s touch a circuit that one, or more capacitors are in, and your fingers complete the circuit, the charge can be released to You!
BAD shock to FATAL!
The capacitors are discharged in a proper manner, with a proper device, before working on an electronic device. (One example is a computer Power Supply)
problem solved replaced board works great took out the switch and not needed not sure why it was there....
