Question about Konica Minolta magicolor 2300DL Laser Printer
Paper jam message on Magicolor 2300W
Using and setting the printer for 8.5x11 inch paper results in the paper ejecting all but the last inch or so from the top resulting in a paper jam message. Selecting a 10inch long option on the printer menu but using the 8.5x11 inch paper allows the page to print without the jam message. I have cleaned all visible areas of the paper path. This is a three year old machine with the problem only now happening
  • 3 Answers
How do you clean the rubber rollers, hope you didnt use solvent....
Use dry cloth with dishwashing fluid only to wipe the rollers.  You will notice the increase in grip immediately.
Posted on Dec 31, 2008
Hello! I have a Magicolor 2300W that has been standing unused for some time and it won't print correctly. The printer feeds paper from the tray, it goes through the printer, comes out at the top - but...
1. Check the paper size your printing on and whether the Same is used by printer or not 2. Try shaking the cartridges as they may have got stuck at their places for long time 3. Try legal or a4 or letter size for paper
Jan 01, 2014 | Minolta magicolor 2300W Laser Printer
Paper Jam at Tray 1
The solenoid may be getting stuck, the only way to check is to remove the solenoid and check that it opens and closes smoothely.
May 26, 2013 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300W not transferring toner to paper.
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
Jan 28, 2013 | Minolta magicolor 2300W Laser Printer
Printer will not pick up paper and gives a paper jam error at tray 1. There is no paper jam.
change or clean the pickup roller for the first tray, and make sure no small paper stucking on sensor , check the sensor if its on right place or not broken. and u will be fine.
Clean the pickup rollers by alchohol
Mar 09, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Paper keeps jaming!
Print a test page, then when it jams, notice if the paper made it's way in to fuser (toward the back of the unit. If it got that far, your fuser may be bad.
Let me know.
Nov 22, 2008 | Minolta magicolor 2400W Laser Printer
Magicolor 2300DL Question?
One thing you should try first, is open the paper width guides( paper loading tray), as if they are set too tight that will cause the paper not to lift up to the pickup roller.
Delboy
Aug 15, 2008 | Konica Minolta MAGICOLOR 2300W LASER...
Paper jam, cleaner kit
If the paper is not situated perfectly in the tray, and it cannot grab the top sheet easily, mine will give the paper jam message. I just adjust the paper in the tray, then open one of the doors, front or back, and close it again, and it usually fixes the "Jam".
Jun 23, 2008 | Minolta magicolor 2300W Laser Printer
Paper jam
open doors and find these solenoids, clean them and make sure they are moving fine, its not so hard. just step by step move with paper and find out where the solenoids are. solenoids aren't expensive so if its a solenoid problem you should fix it
May 28, 2008 | Minolta magicolor 2300W Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
316 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
