On a zoom g2.1u, the edit light stays on by flashing all the time.
  • Anonymous Dec 30, 2008
    someone help!!
    i really need this cos we've got a gig coming up and i can't find anything that solves it!
I NEED THIS TOO....SOMEONE PLEASE HEEELLPPP
Posted on May 09, 2011
Does anybody know if there is a patch list for 0 - 39 on the Zoom G2,1u ?
Larry
Posted on Jan 15, 2009
Kodak
Call Kodak at this #.... 1-800-822-1414
Regards,
Dennis
Aug 28, 2014 | Kodak PIXPRO FZ41 Compact Digital Camera -...
I have a 2001 vw jetta wolfsburg edition and just recently my traction control and abs lights came on in addition to my e-brake light flashing as the same time. it only does it sometimes. when i start the...
the lights should come on when you start the car,then go off about 10 secs after the engine fires.if it comes on at other times then it needs to go onto diagnostic computer.asap.
Mar 26, 2010 | 2001 Volkswagen Jetta TDI
Will not stay on
When the zoom motor start malfunction then this error shows, to rectify this problem you have to replace the zoom motor(if component level repair is available) or you have to replace the optical zoom lens complete assembly. After replacement your camera work fine again.
Thanks for using fixya.
Jul 29, 2009 | Cameras
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Automatic zoom
auto zoom will only work while the build-in wide-flash adapter is slided inside.
Apr 05, 2008 | Nikon Speedlight SB-600 TTL Flash
Red light
Check that you have all the correct drivers installed, ie....for your ethernet. Look at the back of your pc at the yellow cable, if the light inside the connection isnt flashing, then your pc isnt recognizing your router and it most likely is a driver issue. Open the management console then device manager look for network adapters/controllers if you dont see any you dont have any and this is your problem. Install the correct drivers from your manufacturers web site and this should resolve the issue.
Dec 17, 2007 | Zoom X6 (5590) DSL Modem (55900003)
580 ex speedlite
Turn on flash while pressing some of those buttons with good batteries
Try switching from Meter to Standard Mode and move head around.
Try move the flash head(flash tube) in Manual mode.
It's in electronic locked up because you're moving that flash tube zoom too much. 98% of photographers use that mode:-(
Alexander
atdlee@netzero.com
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
Built-In Speedlight (Flash) will not retract
I haven't heard of this problem but compliments of velocityreviews I came up with this. Follow the instructions below to attach an external Speedlight. Refer to your Speedlight manual for detailed instructions regarding Speedlight operation. 1 Make sure that both the camera and the external Speedlight are turned off. 2 Attach the Speedlight to the camera accessory shoe. 3 Turn both the camera and the Speedlight on. 4 Set the external Speedlight zoom head to an angle wider than 28 mm. If you are using a Speedlight with Auto Power Zoom, set the zoom head angle manually. The COOLPIX5700 does not support power zoom. 5 Set the external Speedlight flash mode to TTL. At this setting, the amount of light produced by the external Speedlight is measured by the camera?s photocell, and the flash shooting range adjusted automatically to ensure optimal exposure. D-TTL flash control (available with the SB-80DX, SB-50DX and SB-28DX) is not supported. 6 Take the picture If the Speedlight Options: Speedlight Control option in the SET-UP menu is set to Auto, only the external Speedlight will fire. If this option is set to Int & Ext Active then the external Speedlight and the builtin Speedlight will fire at the same time. The COOLPIX5700 does not support AF-assist illumination, or red-eye reduction using the red-eye reduction lamp on the external Speedlight. At a setting of STBY (standby), the Speedlight will turn on automatically whenever the camera turns on but will not turn off automatically when the camera turns off. Exact functionality varies with the Speedlight in use. Refer to your Speedlight manual for details. I hope it's of some help BMW
Jul 07, 2006 | Nikon Coolpix 5700 Digital Camera
205 people viewed this question
 Grubhead
Grubhead
