Question about JVC RC-QN2 Cassette/CD Boombox
How do I set the clock and preset stations.
I received this stereo from my friend and I can not figure out how to set the clock or the preset stations. I tried to download a manual, however I do not want to pay $15 to answer these two questions. Please help.
  • mikeybrow Dec 02, 2007
    cant find a user manual HELP!!!
I also had some problems to figure out how to set the time, but here is the sollution i came up with:
1. Press "Clock/Timer" until a clock and "on" starts to flash in the display.
2. Turn the "volume/caleido jog" to choose which function you want to set (alarm on/alarm off/time).
3. Press "clock/timer" again.
4. Change time with the volume wheel.
5. Press "clock/timer" when you are finished.
Posted on Oct 16, 2007
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
I have a 98 ford winstar I'm installing a pioneer
You'll need to check that you have the yellow wire connected to constant battery, power from battery, not thru the ignition switch. The yellow wire is the power wire for the clock and radio presets.
May 13, 2010 | Car Audio & Video
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
Fitted clarion db148r car sterreo(pluged in at rear) when i take ignition key out stereo switches off and all preset radio stations are lost thanks george
The reason you are loosing all of your presets, clock & eq settings is because the 12volt constant is not hooked up properly. The red wire in the harness needs to be hooked up to 12 volt consant. The yellow wire needs to be hooked up to a ignition source. By taking these two steps, you should have normal operation and preset retention.
Sep 13, 2009 | Clarion DB148R CD Player
Can't Set Presets for Fm radio
when u get it to the radio station u like.... on ur cd player u should have buttons 1-6 or somethin close.... when ur at the station u want to be preset... pick a number 1-6 and hold that number in for about 5 seconds... it should notify u some how... it should preset itself when u do this
Jan 16, 2009 | Sony CDX-M8800 CD Player
I do not know how to set the clock on my stereo
try pressing and holding clock button.. then while still holding clock button press fm preset #1 for hours and preset#2 for mins
Jan 14, 2009 | Pioneer DEH-P6800MP CD Player
How do I preset the stations for an Alpine TDA-7547 car Stereo. This is an older stereo and setting the stations is not intuitive.
Select the station you want. Then hold down one of the 6 preset buttons for a couple seconds. When the station ID flashes, release the button and it should be saved.
Dec 06, 2008 | Alpine TDA-7547
Jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Aug 25, 2008 | JVC AM FM CD DET FACE CAR STEREO
How to reset a deh2700 clock
I HAVE FIGURED IT OUT..
You have to hold the audio button in the top right corner till the time blinks, then use the arrows to set the time and then hold the audio button again when finnished.. AND YOUR DONE!!! It makes no sense why you wouldnt have to hold the clock button like most any other radio is BEYOND ME... screw all this hidden stuff..
Jun 19, 2007 | Pioneer DEH-2700 CD Player
JVC RC-QN2 Cassette/CD Boombox Logo
884 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
