Question about Refrigerators
Whirlpool Refrigerator Shelf falling off support pins regularly
The shelf, which goes in the refrigerator door supported (supposedly) by white plastic pins, doesn't seem to be wide enough because it falls off the pin support regularly causing things to come crashing down. I'm at a loss on how to fix it, where to find a wider shelf or longer pins to support the shelf. Rest of refrigerator works fine!
I got a new refrigerator that has the same problem. I solved it by cutting a triangular pencil grip for children's pencils down so they extend out just past the pegs on both sides (making them longer). The grips fit on snug, just like on a pencil, you don't have to screw the shelves in permanently which allows them to be taken off and moved. Works like a charm and holds the shelves in very snug.
PAM
Posted on Apr 05, 2009
Door shelf, need to take it apart.
Gently squeeze the sides of the clear door to allow its pivot pins to disengage from the surrounding plastic. After cleaning, repeat the process to reinstall it.
Dec 02, 2017 | LG LBC22518 Bottom Freezer Refrigerator
Flap on Ice chute came off I need to put it back on. Whirlpool Refrig. With water and Ice with a flap over the ice to keep hot air from getting in.
I'm in the middle of the same problem on my own refrigerator right now. The flapper swings on a steel pin which passes through a stationary plastic tab. That plastic tab can break off, allowing the door to fall out of position. Look up into the mechanism to see if this is your problem. Whirlpool makes a modification kit, part #8201756. It's not on the original parts list, so do a web search for Whirlpool 8201756. I hope this helps.
Jul 10, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The refrigerator door side does not shut tightly. The gasket seems to be ok and we leveled the unit. Still not shutting tightly like the freezer side which seems to have a magnetic pull to assist close....
Check bottom hinge cam riser located on bottom hinge the pin that goes inside the door it's plastic it's a 2 piece part 1 part goes over hinge pin and the other goes inside door hole. They get worn and break. If you replace this make sure you get both parts until you do try adj. top door hing to get the door tighter.
May 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
GE side by side freezer shelves falling down
This appears to be a known problem with at least a couple of GE models (It has been happening in our freezer too). There is a GE Service bulletin at https://customernet.geappliances.com/OTIS/fs/home_images/REF01-10.pdf that seems to describe the fix as them sending out new shelves (and maybe someone to install them?)
Sep 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Door to refrigerator will not close properly.
The refrigerator door seal is being broken when you open the freezer door? Sounds like the rubber magnetic strip needs to be replaced on the refrig. door, they wear out after a number of years.
Oct 28, 2017 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrig door trays do not stay in place. Door studs too far apart.
Hi there. Take one of the trays to a hardware store or even a home depot and but a 12 inch piece of clear plastic tubing which fits snuggly over the studs. Cut the pieces just long enough so that the trays snuggly fit into the refrigerator door. This will solve your problem for a few cents compared to a very pricey repair kit from the manufacturer of the refrigerator. good luck.
Feb 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer door needs to be raised
just put some washers (plastic washers are best) on the hinge pin to raise the door
Nov 16, 2008 | Whirlpool ET0WSRXML Top Freezer...
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Refrigerator
need to know brand locate the serial plate on most brands it's in the refrigerator compartment then i can name your part
Dec 30, 2007 | Refrigerators
Refrigerators Logo
777 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
