Maytag Washer Stopped Working
My Maytag LAT4400 washer filled with water (level was set between Large and Extra-Large) and then stopped. The lid switch seems to be clicking in and out okay, and power is okay. I tried the dial at other positions but nothing happens. I did another load earlier today with Large setting) with no problems.
I was about to order a new lid switch assembly, but I decided to try one more thing. I disconnected the wires from the check switch and cleaned the connections - there was a layer of oxidation. The machine started right up after I reconnected the wires and plugged it back in.
Posted on Dec 18, 2008
SOURCE:
I have a maytag top loading washer. the washer if set to medium load or large or super large load only fills to the half full level,
My maytag has a rubber tube that goes from the bowl up to the level sensor. I would try removing this tube and blowing it out to make sure that it is clear and not perished.
May 26, 2015 | Maytag Washing Machines
GE profile washer wont fill all the way with water. Can only wash 2 pants and 2 shirts and its set on extra large load.
A lid switch doesn't regulate water capacity and if the lid switch fails, the machine will not execute a complete wash cycle. If the washer functions but only at partial water fill for the selected load level... then the problem is likely a clogged pressure switch tube or a malfunctioned pressure switch. Got mine used online - fixed the very same issue.
Mar 19, 2014 | GE Profile WPRE6100G Top Load Washer
My speed queen washer wont fill all the way up on extra large setting. How can I adjust the water level switch so that it will fill up to the top? My model is Awn542
This is mentioned in the manual-the federal gov't has required manufacturers to set water levels lower to conserve water. You can fill it more by holding the load size level to reset until it has the amount you want.
Jan 20, 2012 | Speed Queen AWN542 Washer
Washer is full of water and completely dead...
the maytag atalntis is a great machine but often falls victim to the lid switch problem
try pushing in the lid switch, right in the middle on top of the lid
you will se a lil plunger, push it in
AP4008646
goto appliancepartspro.com
runs aound 20.00 but im sure thats your issue
Oct 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Maytag Washer Just Stopped After it Filled With Water (Timer?)
Cant rule out the timer but I suspect first check the lid switch. The timer and other components are fed from the lid switch on most models. Just put the2 wires together and reapply power if it works replace the lid switch. If not you'll have to have a wire diagram to know where to check next, but your water level switch "fill switch" could be at fault. it stops the water valve 1 way and can energize the rest of the circuits the other way. It may not be closing in the "full" direction. Again this switch if so wired will have 3 wires on it.
Mar 24, 2009 | Maytag Washing Machines
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
399 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
