Question about Kenmore 41389 Electric Double Oven
Electric double stove
I acquired the double ovens but not a manual. It has a cleaning button which cleans the top oven but there is no indication of how to clean the bottom one... Help?
Well damn that isn't what I wanted to hear but its what I expected! Thanks so much for your response! Have a great weekend!
Posted on Apr 21, 2007
    Sniper:
  • 68 Answers
Some double oven models have only one that is self cleaning. If you do not have a cleaning button for the bottom oven, it is not self cleaning. The solution is to use the top oven for those messy baking or roasting chores and use the bottom oven for the clean baking chores.
Posted on Apr 14, 2007
My double ovens do not work unless I keep the buttons pressed in the whole time I need for cooking, when I let go the ovens go out?
YOU NEED A NEW CONTROL MODULE, THAT PANEL IS A COMPUTER BOARD AND DOES BREAK. EITHER FROM HEAT EXPOSURE OR CLEANING SOLVENTS
Dec 05, 2014 | Stoves 720EF Electric Double Oven
How can I clean the roof of my Stoves 720EF Electric Double Oven
I have been using the Lakeland brush on oven cleaner for ALL of the inside of the oven including the stay clean bits without any problems. With the 720, I just brush on the cleaner and follow the instructions. To answer you question, I don't actually lie upside down, you should be able to reach it fairly easily. You may need a number of attempts to get the worse of! Be careful of the thermostat sensor at the top rear right of the oven. It should be bright and clean but will not take any heavy handed cleaning, especially the thin wire leading to/from it. FYI the fan cover at the rear of the oven is held on by 4 self tapping screw and comes off/ goes back on with any problems.(The rear of the cover by the vents build up with grease). Don't use the cleaner on any aluminuim bits ( which includes the fan) as it harms it.
Dec 31, 2011 | Stoves 720EF Electric Double Oven
I have a stoves double oven the fan oven heats up but not hot enough could it be the stat and if so how do i replace it.
It could be the stat. First check that the sender unit located at the top rear of the oven above the fan cover is bright and clean and not covered with dirt and grease. Use a paint on oven cleaner to clean it in situ as it is quite easily damaged. Lakeland do one. If that doesn't work, then the whole oven unit will have to come out of the kitchen carcass and the the top and rear oven covers removed for access. Try espares for the part. If you want to check the oven temperature before you start, Lakeland do an oven temperature thermometer for about £5 which I have found is accurate.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
I'm having trouble setting the oven to manual-pressing the cook time and the ready time simultaeously no longer seems to work
It could be that the contacts need some cleaning. Turn the power off and then repeatidly press the buttons. This action may will clean the contacts. If this doesn't work then a new timer from espares is about £80.
Nov 17, 2010 | Stoves 720EF Electric Double Oven
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven and Stove top don't heat up but indicator lights on
there may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
Mar 17, 2008 | Ovens
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 41389 Electric Double Oven Logo
198 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
