Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4t not draining
My washer is not running a full cycle. So there fore it is not draining. When I go to manual drain it wont drain either.
    Genius:
  • 1,199 Answers
The belt that makes the washing barrel spin is broke or out of aline (this is an inexpensive fix!)
Posted on Dec 17, 2008
  • 153 Answers
See if anything is stuck in the outlet
which causing the water to stay inside
    Guru:
  • 829 Answers
Phone the recall department 1 800 469 4663 if enough of us do it they will do a recall
  • Kenmore Master
  • 19,396 Answers
Check if the drain hose is free first, if the drain lines are not blocked, then there is need to remove the drain pump and clean the hose in there, or replace the pump.
  • Ginko
    Ginko Dec 17, 2008
    There is a drain filter, near to teh pump that must be checked. To check the drain filter the machine must be unplogged from power and water supply closed.
    To check the pump there is need to remove a panel held with three screws, there the pump must be removed and cleaned, a lot of water will come out when removing the pump.
    The job should be done by a technician.
    You can find machine parts and diagrams by entering model number here.
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Draining Problem
Check for advice and solutions under "Kenmore Elite HE4t Washer" problems on this site. We have a Elite HE, but they are set up the same and the solutions should help you out. I've been dealing with the same issue.
May 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
166 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
