Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
I cannot adjust the Power plus 16000 btu burner
I have a glallery series slide in oven/range that is operating on LP gas. On the low setting the burner is way too hot and I don't seem to be able to adjust it down like I can with the others. What would be the problem. I can turn the set screw but the flame does not go down on low!
5 Suggested Answers
SOURCE: Oven does not heat
I am having the same problem right before the holiday...can this be by myself or do I need a technician??
Posted on Dec 16, 2007
trav1856
  • 57 Answers
SOURCE: flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Posted on Dec 06, 2008
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 22, 2010
SOURCE: Frigidaire professional series gas stove does not
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Posted on Feb 21, 2011
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
I need to know the btu input for a ge cooktop (gas) model gejgp975sekss
I see if I can find a diagram, ensure you posted right model number here.
Aug 29, 2008 | GE Kitchen Ranges
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
New kenmore gas range 790.7433 converted to lp and oven flames are way too high and produce lots of soot...how fix?
Do the rangetop burners act OK, Brenda? It's just the oven that's causing a problem?
Go back to the oven burner, right where you installed the new orifice. That orifice should fit inside an air mixture tube, probably stainless steel, leading to the burner itself. Right where the orifice fits into it will be some means of adjusting the air mixture - a sliding window of some sort, whether flat or round. You'll need to loosen the screw holding it in place (DO NOT remove the screw, only loosen it) and turn it so the air opening is larger. Right now you're getting too "rich" a mixture, too much propane & not enough air. Before you close it all up, try the oven again - see if your adjustment worked correctly. If not, adjust it again - this is a trial-and-error process, and it's different for every different altitude and climate.
At some setting, you'll get a nice blue flame with very little orange in it. If you live in a very high humidity area, you'll have much more orange color than people who live where it's very dry, but the flame should at least be MOSTLY blue, and should never be sooty.
Aug 01, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Manual
When the range top burners and the oven are both not lighting, I recommend you check if the manual shut-off valve to the range has been turned off. With most of my gas ranges, you have to remove the drawer to reach the shut-off valve. (so If you have propane, make sure that your tank isn't low.
Make sure that your home is well ventilated; open the windows and check the range in a while. I live in an area where we had to add a whole house ventilator. We had days where the house would seem stuffy and none of the burners would light. (Appliances with pilot lights went out.) This was due to excess carbon dioxide shifting from nearby coal and natural gas deposits.
It is possible for the igniters to fail if there is power to the range, but usually not the oven, the broiler and all of the top burners at once. You can test the top burners carefully with a long handled butane lighter or a long match. Turn on the hood fan and set a burner to the Lite position. Carefully, light the lighter near the burner or bring the lit match to the burner. If the gas is flowing properly and there is sufficient oxygen, it should light. Then remove the lighter or match and put it out. Then adjust the burner temperature.
The manual for the ARGS7650SS is available from Amana. The direct link is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/31810401.PDF . Many newer Amana product manuals are available here: http://shop.amana.com/product_literature/search.jsp .
I hope this helps.
(note: you should also make sure that the regulator cap is correctly set for your type of gas (LP or NG). The gas flow rates are different enough to make the regulator fail. Most ranges are shipped for with the cap set for NG. Turn off the gas and unplug the electrical cord before working on the regulator cap. The burner orifices need to be changed as well as some other adjustments to convert from NG to LP. See pages 9-11 of the manual for details.)
Jun 26, 2013 | Amana ARGS7650SS Gas Kitchen Range
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Swithed to LP
did you change the ovens burner orfice?if not theres your problem.
Dec 25, 2007 | Maytag MGR4451ADS Stainless Steel Gas...
Cannot adjust flame on gas burner
Is this lp or natural gas? The screw you turned adjusts the low flame only. Did this just start, or has it always done this? Let me know.
Nov 20, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Flames in oven are WAY too high! Having trouble lowering them.
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Jul 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
61 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
