Question about Panasonic PT-43LC14 Television
Flashes orange 2 times every 5 seconds
According to the manual I need to tighten the lamp cover. I have tried this several times and doesn't work. This problem started last Aug of 2006. It would flash orange and I would unplug the TV and wait 5 minutes and plug it back. Turn TV on and it would work for months before having the problem again. When I called Panasonic support they first said it was the lamp, after I told them the lamp is working they told me they didn't know and to call a TV service man. The past month the TV is going off daily and sometimes will not restart until next day. Sometimes it will stay on for hours and then sometimes only minutes. Can someone help me with this problem? thanks Steve Barton
    President:
  • 1,284 Answers
There is a 20 pin cable that goes from the main board to the light engine that can cause this issue. The other possibility is the door switch or the cable that leads to it has failed. If none of those correct it then the light engine itself is the problem. Hopefully one of the earlier mentioned items is the issue as the light engine is costly. The part number for the cable is LSJA0467 and is available here http://www.partstore.com/PartNumberSearchResults.aspx?PartNumber=LSJA0467
Posted on Mar 26, 2007
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
The power light is blinking orange???
Flashes orange 1 time every 5 seconds. The internal cooling fan is not working.
Flashes orange 2 times every 5 seconds. The Lamp Cover is unsecured.
Apr 22, 2010 | Panasonic PT-60LCX64 Television
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
Lamp/cover light flashes orange
could be need new lamp
very expensive!!
how old is the tv?
is this the first lamp?
usually get 10000 hours use out of one lamp
Jun 01, 2009 | Televison & Video
Sony Projector
Ok we're back to the flashing lamp cover LED. The green flashes you are seeing is the TV trying to start up. After it tries for awhile, it will eventually shut down and display an error code, in this case, the lamp cover LED flashing which means either the lamp cover, filter cover or main cabinet sensing switches are not closed, are intermittent or have some kind of wiring issue. A solid lamp cover light (no flashing) would point to the lamp and lamp drive, but the flashing light points to the switches. Give me an email address and I'll send you the training and troubleshooting manual so you can see for yourself. Any ther help needed, please don't hesitate to ask.
Nov 01, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
3 flashing red lights
3 times flash shows error in Lamp Cover. Please check lamp cover at back of tv and set it properly, if you removed it.
Let me know if
have query.
bye.
Sep 08, 2008 | Sony KDS-R50XBR1 50" HDTV
Ink tank lamp lights not coming on when ink cartridges installed
Remove tape from the ink tank - MP800R / MP830 / MP530
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads. It is necessary to adjust air pressure outside and inside the tank so that ink flows properly. If ink does not come out, check to make sure that the protective film has been correctly removed.
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    Caution:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the tab to release the ink tank (1), then remove it from its slot (2).
    Caution:
    a. Do not remove the print head from the machine.
    b. If several ink tanks need replacing, remove and replace each one individually.
  5. Check the ink tank. If the orange tape is as shown in Figure (1), it is properly removed.
  6. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  7. Insert the ink tank diagonally into the print head.
  8. Press it in firmly until it locks into place.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  9. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  10. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Dec 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Panasonic PT-43LC14 Television Logo
176 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
