Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera says card locked
I have a Casio Exilim, i got it in July and it worked great until about a month ago when i turned it on the screen said "Card Locked". I took out the memory card to make sure that the switch was not on lock and put it back in the camera. It still says "Card Locked" even thought it's not. If I take out the memory card I can still take pictures but with it in I can't do anything but look at the pictures on the card.
1) Try to unlock it by the lock/unlock switch on the side of the memory card.
2) If step 1 does not work replace memory card with new card.
3) If step 1 & 2 do not work the problem is internal (inside the camera). Go to www.ecasiorepair.com to get a quote for repair. Cost will be anywhere from $39-115 to fix it (if not under warranty). You could even ask if this is a defective camera (lemon) they might even fix it for free? I've seen this issue with the Casio a lot.
Posted on Dec 17, 2008
When I switched on the camera, the screen showed me "The card is locked" I assume it's talking about the memory card...but why???? My camera is a Casio Exilim EX-Z600
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 21, 2010 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Casio exilim Z75 When camera is on screen reads
Sounds as though the sd card release spring has broken (in the camera card slot.) Perhaps a pair of tweezers and a good pull will get it out? The card not the broken side spring. Hope this helps!
Jul 20, 2010 | Casio Exilim EXZ75 Digital Camera
Take you memory card off the camera and on the side of the card you should have a small lock symbol. Make sure this is set to unlock
May 16, 2010 | Casio Exilim Zoom EX-Z9 Digital Camera
Kimly may -casio exilim the card is locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 05, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Casio exilim ex-80 always shows SD card as locked
the SD card should have a small switch on the upper left side it slides from lock to unlock if this doesnt work Look in the card slot - there may be a small bit of plastic sticking out over where the card's locking switch would fit when the card's inserted.
Oct 25, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Casio exilim 8.1 card is locked
Hi!
Can you check if there is a small push button on the memory card itself? It could that it is currently on write-protect mode.
Aug 29, 2009 | Casio Exilim EX-S600 Digital Camera
Canon Powershot screen says SD card is locked
Have you been to the Casio website to check for firmware updates?
Aug 26, 2009 | Casio Exilim EX-Z750 Digital Camera
CASIO camera says screen card is locked, mem. card is on unlock..
thank you very much, it was the card when i removed the card it worked. again thank you
Jun 06, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Casio EXILIM EX-Z110 (the card is locked)
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jul 02, 2008 | Casio Exilim EX-Z110 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
215 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
