Question about Durabrand CMV-102A CD Player
Wire harness i removed my cd player from my old car before sold it was ready to put it in a new car and i forgot to remove the wire harness from the old car,is there a way i could get a new harness or even a used one i would really appreciate it very much,i miss my music.......ceecee
    Scholar:
  • 135 Answers
You may be able to buy a new harness from Crutchfield (www.crutchfield.com). Give them a call (the number is on the website), they are open 24/7.
Posted on Mar 26, 2007
How do you put normal cd player in 2004 model ford fusion
You will need an adapter kit for the dash panel specific for the Fusion or a multi kit, both availible at an Auto Parts store. You should also buy the wiring harness for the Car as well, this will make life much easier on you! Connect the harness to the stereo, following the schematic/diagram. Pop the dash panel apart and remove the old stereo. Slide the adapter plate over the wires FIRST, then connect the wire harness, put the adapter plate in place and then slide the stereo in place, re-assemble the dash...
Jun 11, 2012 | 2006 Ford Fusion
My daughter has a 98 olds 88 i removed the stock stereo and put in a pioneer cd player but i didnt see any wire on the stereo side for the elec. antenna i was wondering how i can wire it to work
Most aftermarket pioneer cd/radio decks have the electrical connector for the antenna that I've seen.
Is this a cd only deck, or does it have radio functions?
Did you use a new harness wiring adapter to get the pioneer radio to work with the old harness?
There should be a color coded set of wires for the power antenna on that. And, then the Pioneer radio should have wires that were labeled for the power antenna.
Oct 08, 2010 | 1998 Oldsmobile 88
How hard would it be to put a different cd player in my 2003 Monte Carlo SS ??
It is very simple actually. What you will need is a face plate, an aftermarket wire harness and the skills to connect this wire harness to the new CD player harness, they are usually color coded so very simple. TO remove you stock CD player you will need to pry off the plastic surround then there are 4, 7mm bolts that will need to be taken out and the stock CD player will pull out. Unclip the wire harness and antenna
Apr 01, 2010 | 2003 Chevrolet Monte Carlo
I want to put my stereo in my car that i just got, but the wires that are in the dont match the wires on the back of my cd player. why is this?
because you will actually need to take the wiring harness off of the original stereo and splice the old harness to the new stereo
Feb 10, 2010 | Pioneer DEH-P2900MP CD Receiver...
Can not find where to plug CD player to the harness
does the radio have cd changer controlls? if so you may find the wires in the trunk if not you will have to buy a harness from ford and make sure the cd changer will work with the stock radio. Call the local ford dealer parts dep but make sure you have the vin number from the car with that they can look up the car and tell you what options where installed from the factory and can order the correct cable
Sep 02, 2009 | 2000 Ford Taurus
Im trying to find where i can gt a complete guide on how to install a car stereo from color coding the wires to installing a dash kit
  1. DISCONNECT THE NEGATIVE TERMINAL ON YOUR BATTERY!
  2. For an old stock stereo, you may have to remove the dash or certain parts of it to access the stereo. Do that by locating screws and bolts and taking them off. Make sure to keep them in a safe place.
  3. For an aftermarket stereo, insert DIN tools into each slot on the stereo behind the faceplate. Slide the whole stereo out.
  4. Disconnect the antenna wiring (The wire with the big metal tip)and the stereo head unit wiring (wire harness).
  5. Reconnect the antenna into your new stereo.
  6. Use **** connectors and wire crimps to connect the stock wire harness with a car specific one that is sold seperately. The color of the wires on each harnass should match up.
  7. Reconnect the negative terminal on your battery and see if it works.
  8. Slide the stereo back into the dash and remount the dash that you removed, including screws and bolts.
hope this will help you
Jun 05, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Problems with car audio
you should plug in the new harness and meter the wires to make sure there is power on two of the wires one will always be powered for memory the other should be powered when ignition is on if both test ok then check the in line fuse links on the radio wire harness I hope this helps good luck....
Jan 10, 2009 | Sony Xplod CD Player w/MP3 Playback...
Missing Wiring Harness
You can call any authorized service center for Pioneer and ask them to order one for you. You must get it from Pioneer.
Use this link to find a Pioneer authorized service center by putting your information in the menus at the top right. Then call the closest one to your home and they can get it for you.
http://www.pioneerelectronics.com/PUSA/Support
Nov 06, 2008 | Pioneer DEH-235 CD Changer
Wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
Jun 02, 2008 | Pioneer DEH-P2000 CD Player
No sound
see solding points of the conectors in the radio and if the MOSFETis good(see if it is hot)
May 03, 2007 | Pioneer DEH-P6400 CD Player
Durabrand CMV-102A CD Player Logo
106 people viewed this question
Top Durabrand Car Audio & Video Experts
Steve Allison
Steve Allison
Mohamed Ismail
Mohamed Ismail
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
