Question about Philips GoGear SA178 MP3 Player
I have a Philips MP3 player, loaded. I am listening to music but want to turn it off. There's no OFF button
Hold the middle button for a few seconds that shoulsd do it
Posted on Dec 21, 2008
  • 4 Answers
Get all the songs off the the mp3 player and then format the mp3 player and then get the new frimare for it then put all the songs back on it how long have you had it!!
Posted on Dec 18, 2008
3 Suggested Answers
SOURCE: I HAVE AN EMERSON MP3
I have an Emerson 2gb MP3 player model EMP 312-2, not sure if this info is for you or not. Make sure you are in the MUSIC MODE, when you use the menu button to go from music mode, voice mode, settings etc. you must push menu button again when the mode you want is hi-lited. I had a similar problem. Files were loaded (my music is on my harddrive already so I just copy to mp3 player) but when I turned player on it said no files. AHA, I finally realized I had somehow got into the voice mode and I did not have any voice files, so it said no files. I then went to Folder Mode and it only said micin.dir and it was empty, THAT WAS BECAUSE I WAS IN VOICE MODE, when I switched to music mode, they were all there. I know this sounds very rudimentary, but I am pretty computer literate and had no idea how I switched to voice mode. Before I figured this out for myself I called Emerson customer service, they said it was bad firmware and send it back. If someone there had walked me through what I just told you it would have saved me a lot of time. Hope this helps.
Posted on Apr 01, 2009
  • 101 Answers
SOURCE: i dont know how to transfer music to my philips mp3 player
I have a phillips go gear. If you have the songs in mp3, simply plug in your go gear using the usb cable provided, a screen will apear confirming that your go gear has been recognised asking you what you want to do click on open folder option.
Now you just need to drag your mp3 into that folder and there you go, music transfered
Posted on Jun 29, 2009
Describe your GOGEAR SA6045 (4 GB) MP3 Player Problem My son installed music in my player. He is now gone in the Army & I can only turn on the radio. Don't know how to get to music installed
Turn on your player and you should see and listen to radio. In this situation press menu key and then select music icon and the select for example all songs. Finally press play button.
This picture will help you finding the menu key:
I hope I helped.
Thanks.
gylacz
Aug 24, 2011 | Philips GOGEAR SA6045 MP3 Player
Philips gogear SA 1828 player hanged while playing music
possible problem is the files or the song that you are trying to listen is currupted.delete it and replace it with other.
Sep 27, 2009 | Philips GoGear HDD1830 MP3 Player
This thing does not work always says ok to disconnect
When the mp3 player is connected to the computer, the only message it will generally give you is "OK to Disconnect" - this is normal.
Once you disconnect the mp3 player from the computer, then you can find your music, listen to music, etc.
If you are getting the "OK to Disconnect" message when the mp3 player is already disconnected from the computer:
Reset the player first.
If that fails:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Feb 28, 2009 | Philips SA3025/37 Flash MP3 Player
My philips music device froze on me. i was trying to put music on and when i ejected it it froze in my music. i cant turn it off, change the song, or listen to music. please help!
There is a reset button.
If it freezes again after reset, go to Philips website, get the upgraded version of the Philips Device Manager and run the Update tab in Philips Device Manager.
-Tha Mp3 Doctor
Feb 18, 2009 | Philips SA3025/37 Flash MP3 Player
When i burnt music onto my MP3 something happened!!!!!!
Nellbell you still having problems with this unit.
You Might try
Copying and deleating all songs on player then load 1 song and try
Reformat the unit and try again
Update firmware from Samsung site.
Try reset button (Under color cover use a pin)
Sep 09, 2006 | Samsung Yepp YP-F1Z MP3 Player
Philips GoGear SA178 MP3 Player Logo
23 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
