Question about Frigidaire FGF355 Gas Kitchen Range
Ceramic igniter broke- how do I replace it?
The igniter on the right front stove top is broken down the middle and now the burner won't self ignite as it used to. It WILL light with a match so I am so sure the problem is the broken ceramic igniter, I ordered one from a sponsor here. NOW that I have it in hand, how do I replace it? Thanks! Wick
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
  • 184 Answers
SOURCE: No power on right hand side burners
WHEN THE SURFACE SWITCHES ARE IN A ROW ON THE CONSOLE, THEY ARE USUALLY WIRED IN PARALLEL FOR THE INPUT VOLTAGES(RED AND BLACK WIRES ATTACHED TO EACH OTHER). IF THERE IS A BURN OUT OF ONE OF THE WIRES, IT WILL AFFECT THE OTHER SWITCH INPUTS DOWN THE LINE.
TAKE OFF THE BACK PANEL OF THE CONSOLE AFTER UNPLUGGING IT AND CHECK FOR VISIBLE SIGNS OF WIRES BURNT. REPAIR OR REPLACE IF NEEDED. SOMETIMES, THEY WILL DAMAGE THE TERMINAL OF THE SWITCH THEY ARE ATTACHED TO. IF THIS IS THE CASE, THE SWITCH WILL ALSO HAVE TO BE REPLACED.
Posted on Apr 04, 2008
SOURCE: Whirlpool electric stove
My sister has a whirlpool electric ceramic top stove/accubake sistem....the problem is that my husband took the door of the oven off to clean and now he can't get it back on......where on vacation at her house and want to fix it before we leave sept. 30/08. We need help fast.
thank you
Posted on Sep 28, 2008
tony2155
  • 64 Answers
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
Posted on Jun 23, 2009
DeBruce
  • 145 Answers
SOURCE: SMOOTH COOKTOP DISCOLORATION
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Posted on Aug 24, 2009
Igniter glows but why doesn't burner light?
Igniter could still be faulty(not hot enough) or burner control valve
faulty. press the helpful button and check link videos below
Gas Stove Top Burners Not Lighting Not Working
Gas Stove Ignitor and Burner Not Lighting
Daddy Chores Gas range won ignite How to fix it
Jan 22, 2016 | Kitchen Ranges
Lofra service perth
Instructions
    • 1 Disconnect the range's power supply, either by turning off the breaker in your service panel, or unplugging the range from the wall outlet.
    • 2 Remove the burner grates, burner caps and burner bases. On some ranges, the burner bases are secured using screws, which you must remove.
    • 3 Insert a putty knifeicon1.png into the gap below the front of the each side of the range to release the spring clips securing the top to the range.
    • 4 Lift the top, and then have a partner hold the top up. If you are repairing the range alone, place a sturdy object under the top to secure it.
    • 5 Remove the burner orifice containing the igniter that you are replacing.
    • 6 Remove the screw securing the igniter to the underside of the orifice, and then remove the igniter.
    • 7 Pull the igniter wire off of the terminal, and then discard the igniter.
    • 8 Connect the igniter wire to the new igniter.
    • 9 Secure the new igniter to the underside of the orifice using the screw that you removed.
    • 10 Replace the burner orifice, and then secure it into position using the bolt that you removed.
    • 11 Lower the top onto the stoveicon1.png, and then press down to engage the spring clips.
    • 12 Replace the burner bases, caps and grates.
    • 13 Restore power to the range by plugging it back into the wall outlet or turning on the range breaker.
Read more: http://www.ehow.com/how_12064545_fix-ignition-switch-stove-top.html#ixzz2bSNNTBF9
Aug 09, 2013 | Kitchen Ranges
Gas ignitor keeps trying to ignite after stove is off.
Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
Sep 13, 2010 | GE Cooktops
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Top burners work, oven not getting gas electronic ignition comes
The electronic ignition system (a ceramic plate that glows red) lets some power pass through to allow the gas to flwo when it has reached lighting temperature. The ceramic lighter needs replacing. Either that or the general electronic in the stove are shot.
Mar 11, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Ran auto clean for oven and cleaned stove top, not auto lighting
One. DO not use self clean on ranges unless you want to replace parts.
Two. Replace the thermal overload fuse.
Three. The manual should be in the console head.
Feb 22, 2009 | Kenmore Kitchen Ranges
Replacing the ceramic top
I remove the whole hinge and top from the back put the old hinge on the new top then move the burner to the new top put the whole hinge on the back of the oven.. hope is is a little help
Jun 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Stove top pilot light
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top ignition
I have a Kitchenaid Model KGCT365x and need to replace the igniter switch on the front right burner. Can this be done through the knock hole or does the whol glass top have to be removed? If it has to be removed, what is the best procedure to do this?
Jan 01, 2008 | Bosch HES 252/ HES 256 Electric Kitchen...
Some Burners Will Not Ignite
probably a worn wire to the electrode or a cracked ignitor. you are faced with taking off the hobtop and looking - no easy solution. you should not do this unless you are confident and don't interupt the gas path
Apr 06, 2007 | Dacor Preference SGM466 Gas Cooktop
Frigidaire FGF355 Gas Kitchen Range Logo
102 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
