Question about Zenith IQC50H95W 50" Rear Projection Television
IQC50H94W All three guns are lit and produce an image on the screen. In setup the red can be merged onto the blue to create purple. The green is curvy-plumb (vertical) Moving the gun magnets have no effect. Someone in another blog mentioned convergence ICs. Is this a probability?
  • 97 Answers
Was the wvay color present before you did anything? Low voltage from the HV tranformer (flyback) an cause this type of behavior. The crosshair for the convergence set-up should be white when they are all lined-up. The varistor pack for the three tubes needs to be recqalibrated for paper white to achieve this. You should NEVER move the tube alighnment magnets on the neck of the tube unless you replaced the tube itself. The coil on the back can be moved left to right the account for bad cross alighment. Bow and Pin must be done on the convergence board. Slideing the coil away from the front of the tube will blur the image. A convergence board is probably not the root solution for an aging set with daily use. Zenith power supplies relatively last 5 to 7 years at best.
Posted on Apr 10, 2007
    President:
  • 1,284 Answers
The convergence IC's should be the first suspect in any convergence issue. Hopefully you can place the magnets back where they were or you will have that alignment to deal with first.
Posted on Apr 09, 2007
The screen is green and the tint option in the menu cannot be adjusted.
This symptom usually indicates CRT failure. Projection TV's, especially older types use 3 CRT "guns" to project the image on the screen. One is Cyan or Red, one is Green and one is Blue. If the Red and Blue become weak or do not project, the Green gun overpowers the output of the other two. These three "guns" are aligned exactly on top of each other so when all three are correctly functioning, the correct colors are projected on the screen.
Oct 04, 2015 | Televison & Video
Tip
SONY TRINITRON ONE COLOUR PREDOMINANT SCREEN
Sony Trinitron sets are of CRT [Caothde Ray Tube] types. The common fault seen in these type of TVs are any one colour predominant on screen wih sound OK. Either red, blue or green colour with some thin horizontal lines at about an inch apart will be seen on the entire screen. This is totally a display card problem, which can be seen pluged onto the picutre tube neck. There are three electron guns for every picture tube, which emits red, blue, and green beams, which in turn illuminates the phosphor on the screen to get that colour. If no emission from all guns, results in a blank screen, ie black screen without any disply at all. The three colour beams together produces proper coloured picture what we see on screen. These three gun's terminals are brought out by pins of the picture tube outside to which video signals are given in appropriate proportion to produce a TV picture. Normally, all these three pins are biased with a voltage of about 170 to160VDC+ve. Take one colour gun, as an example and and let me describe the problem.
Let it be a green gun. These guns are called cathodes of the picture tube. If it gets a voltage with respect to its grid, it will emit electrons according to the voltage applied to it. This is a negative process, that is, as the voltage at this pin drops, its emisson incresses and vice versa. If the emission increase, the colour with respect to that gun also will increase and gets predominant at the screen. So when we see a green predominant screen, there will be less voltage at the green cathode with resepect to the other two. If red colour is predominant, the voltage at red cathode will be less than the other two. If blue colour is predominat, the voltage at the blue cathode will be less than the other two.
We must find out the reason for this fault first. Assume that your Tv has a red predominant screen with some thin lines across it, at about one inch apart of the entire screen, it is clear that the the red cathode voltage is very lower than the other two. the main reason for this fault, normally seen in most of the Sony Trinitron, are loose soldering points either to the picture tube base socket or the resistor connected between the red drive transistor's collector point. Resoldering the most of these points on the base card by applying a little more solder will rectify this probelm. Other possibility is shorted video output transistor of that cathode. A direct short [collector to emitter] of these transistors will drop volatge to very low at that respective cathode of the picture tube, and that colour will be pridominant along with lines. Replacing the transistor will solve the problem. In some cases, the resistor connected to that transistor may have blown out. If so, it should alo be replaced. Whatever the case may be, voltage at the respective cathode that emits colour will be very low with respect to the other two. Find out the reason and rectify it. You can compare the voltages of the other two cathodes with respect to the faulty colur cathode. Cathode pins will be marked on the base card, and can be identified. It is best to pull out the base card from the picture tube neck and place it somewhere a safe place without shorting it with other parts of the TV. You can measure the voltages of these points very easly, without fearing the damge to the picture tube. After all are found Ok, replug the base card and switch on the TV. The set will be alright. In rare cases, chroma IC also can be a reason for this fault. if it is faulty, after a short period after switch on the TV, the IC will overheat and shutdown the entire system.
on Mar 21, 2011 | Televison & Video
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
My screen went out but i can still hear sound is my picture tube out ? its a 04 65" 1080 series
Your set doesn't have a tube, per se, it has three CRT "guns" in Red, Green and Blue tjat converge the colors on the screen to create the image. It is very odd for them to all go at once which means it's probably a much bigger problem that will not be cost-effective to fix. Better off investing in a more contemporary set.
Apr 23, 2011 | Mitsubishi WS-55809 55" Rear Projection...
I read your answer about kdp-51ws550 regarding the bulb usually the main reason( besides the power supply) dosen't this tv has three bulbs?
Three bulbs, no. They are not bulbs in the sense that you are thinking. The way that it works is there are three small high intensity CRT guns. There are three because most images on any TV can be created with three basic colors. They are Red Green and Blue (RGB). This has been the industry standard since the first projector came out and since color tv came about. Each Gun is pointed at a specific angle towards the Rear of the TV and is reflected off of a mirror then is focused to its appropriate spot upon the viewing projection screen. Gotta love math.
Apr 03, 2011 | Televison & Video
My JVC AV-56WP74 is showing green and purple waves at the top of the screen what is defective?
Common problems with the chassis used in this model for complaints such as this are caused by damage in the convergence circuitry (since there are three separate picture tubes, each mounted in a physical location different from the others, the light each tube "throws" on the screen falls in a different physical location on the screen; the electronics of the convergence circutry force the red & blue light information to "converge" on the image produced by the green tube, which being physically located in the center of the other two is the "master" image), usually associated with the IC's used as amplifiers for the convergence circuits (this model uses STK392-110's) and with the high-wattage, low ohmage resistors used as biasing components for these amps
Mar 04, 2010 | JVC AV-56WP30 56" Rear Projection...
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
Zenith IQC50H95W 50" Rear Projection Television Logo
85 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
