Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag MGR575qdq gas oven
My stove top ranges work but my broiler and baking oven does not. Any suggestion?
    Genius:
  • 1,199 Answers
Replace thermostat in oven and this should fix ya!
(Please rate answer to help keep this site FREE!)
Thank You!
Posted on Dec 17, 2008
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221257
Dec 26, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Oven will not work unless range is lit
You probably have a neutral return that is open. By turning on the stove top you are completing the path of return for the bake element. Work back from the element (unplug the oven first!!!) and check continuity back to the plug. Again, make sure you unplug the darn thing from the AC outlet!
Mar 12, 2009 | Maytag MER5775Q Electric Kitchen Range
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Maytag dual oven upper oven not heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerryrigging a bridge to wire the BAKE igniter to the BROILER controls.(Push/click plugs accessible by opening up the stove back) Testing thebroiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.)The parts and wiring are pretty simple and visual once you get thecovers off. Opening up the stove back is just a matter of removingseveral screws. UNPLUG the stove before you work. If you test as Idescribed, make all connections while UNPLUGGED and then plug it inonly for the brief test. Unplug again while disconnecting/reconnecting.Hope this helps.
Nov 25, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Maytag Gemini gas top oven does not work.
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Jul 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
134 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
