Question about Digital Audio TRIO MP3 Player
Can't delete folders. response is devise not responding
Audiophase 1gb mp3 player. can delete folders. how do you reset the device? should i toss it?
    Problem Solver:
  • 17 Answers
To delete files there are 2 ways to do this.(1) first is with the on and facing you. on top the is the black menu switch. (2)hold down until it reads play music,and release (3) cycle either way until it reads delete.(4) cycle the switch until it reads del / push switch in (5) cycle to voice (6) push switch in to delete files. (cycle to exit and push switch again it should go to your music.
Second way is to plug it into a computer with plug and play.with the Trio MP3 on, the computer should open up a menu, chose open files (2) the screen should have music, voice and other files on the display. chose the voice file and click it open. use the mouse to delete files / or point and use the key board delete key to delete files. IF PLUG and Play does not open up goto MY Computer and openit up. drop down to the removeable disk and click open. you should be where you can delete the voice file. good luck and have fun.
Posted on Dec 21, 2008
I cant delete songs off of my mp3 player
I can't delete my songs. I have tried 4 different media player to delete and they all give me an error message. Failure to delete, not responding can't delete etc... What should I do? I have the pink ilo 1GB mp3 player
Aug 20, 2008 | iLO MP3 Player
Ilo 1GB 3.101.103 MP3 Player = MTP Device?
Uninstall MTP Device in System --> Hardware --> Device Manager
May 18, 2008 | iLO MP3 Player
RCA 512 MB
Well Robert, the main solution to this is the firmware. You need to set the MP3 player on to "Disk Mode" and check for any corrupted files or additional files that you didn't install originally. Like I tell all my clients, It's not whats added to the MP3 player, it's whats taken away. If you can't seem to find your original firmware onto your MP3 device, you need to install a new one, or check for additional firmware that you didn't install. Try backing up all your files before you attempt to install any new firmware onto your MP3 device.
Don't panic!
Bananaboy101
Mar 25, 2008 | RCA Thumbdrive Player (256MB) MP3 Player
My mp3 player just stop working
I had the same problem... I tried pressing the reset with a pen but didn't get any response... so I unwound a paper clip and actually heard an audible click when it reset... then it powered right back up... yay!!
Jan 18, 2008 | GPX MW3837 MP3 Player
Mp3 downloadng
Connect your mp3 player to the computer with the USB cable provided.
Install the software provided or use a program to synchronize it [Eg, Windows Media Player]
If WMP does not work and you do not get sofware with it simply, Open My Computer, Look for your mp3player's file "Audiophase-something", Open this folder.
Keep this folder open and open the folder where you music is stored.
If you do not have music on the computer yet, rip music to it using WMP or download some using Ares or Limewire.
Now that you have both windows open, drag the music to the music folder of your mp3player.
Song.mp3 >drag to> "Audiophase" Music
Dec 27, 2007 | Audio Players & Recorders
Won't be deleted
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Dec 27, 2007 | SanDisk Sansa E280 MP3 Player
Audiophase KZIII 1GB not being recognize or working
Ok for the KZ111 and KZ100 audiophase. turn the mp3 player on. then plug it into the computer. the player will start charging. Go to windows explorer or my computer and you will see it listed as a hard drive. Create a folder called music. you can then drag and drop mp3 files into the music folder. As for charging the battery my Motorola V170 cell phone has a usb charger. I use it to charge my mp3 player takes about 20 minutes. and the charger in my car for the phone works too. Hope this helps.
Sep 04, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Audiophase 1GB MP3 Player
About the charging - you have to plug it in and then turn it on to make it charge. The user manual comes on a small disk with the device. It is extremely unhelpful, as it contains almost the same info as the package insert for quickstarting. The only thing that was useful in the manual was this : Support and Service
Please call 1-818-767-2843 ext 117 for any questions regarding this unit.
Mar 02, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Error when trying to copy files to or delete files from ilo 1gb mp3 player
The Walmart/Asda mp3 players in the uk have the same problem, I have the formatting software on the cdrom that came with it and it doesn't work 'Surprise'. The problem normally happens when you try to either upload mp3's more than one at a time or delete all at the same time causing a file the folder to become corrupt and stop everything. Is there possibly a factory reset menu on the player, if not you will have to search the internet for your manufacturer to see if they have an on-line formating tool.
Jan 13, 2007 | iLO MP3 Player
Digital Audio TRIO MP3 Player Logo
107 people viewed this question
Top Digital Audio Audio Players & Recorders Experts
Tom Chichester
James Hensley
James Hensley
JonSnell Electronic
JonSnell Electronic
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
