Question about Hotpoint 23 in. BF41 Built-in Dishwasher
Hotpoint BF41 stuck mid cycle
My hotpoint BF41 started to to leak at bottom of door. We initally thought that it was the door seal, so replaced seal and hinges. Water was still leaking out of door, and we then decided to watch machine with door ajar, and then discovered that leakage was actually due to to rota arm in bottom of machine had split ways and was pouring water our of bottom of door. We then replaced this part, resolved problem with leak, however, when my husband was the hinges on door he received an electric shock off the door and now leakage problem is resolved machine is stuck mid cycle. Possibly due to electric shock causing a short somewhere maybe? Any ideas? Need dishwasher fixed for XMAS!!!!
  • tommoshouse Dec 28, 2008
    Hi, I have got very similar problems with my BF41. We inherited the machine when we moved into our new house at the beginning of November and ever since have had nightmares!
    To start with it was leaking out of the bottom (which it still does) so we replaced the seal after googling the error. The new seal then prevented the shutting of the door but in the literature it said that in some cases this happens so you need to buy a new lever for the door which we did and still it wouldnt shut!. I re-fitted the existing seal and then within a week the dishwasher has become permanently stuck in the rinse cycle!
    We have now been washing up for over aq week and I am at my witts end as to how to fix the problem, if anyone could advise it would be greatly appreciated.
3 Suggested Answers
  • 3 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Posted on Aug 25, 2007
  • 523 Answers
SOURCE: Hotpoint dishwasher HDA467-02 AD leaks suds/some
tilt dw back
Posted on May 30, 2010
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
My BF41 Hotpoint integrated Dishwasher seems to have stopped mid cycle and now won't reset. There was a small amount of water in the bottom and the element was still heating the water. Even after a full...
I've had this issue with my thermal fuse blowing. If the water gets too hot, this will trip. If you have a meter and know how to handle yourself around electricity (power off and verified), then you can pull the liner out to get to the electronics. (I don't know the exact method for the Hotpoint). Follow the power lines and you'll find the fuse. Mine has two wires connected to tabs on a little card. If the fuse shows open on the meter, then you can get another for just a few bucks off your favorite auction site, or local appliance parts store (a few bucks more, but immediate delivery). If you have the hot water heater temp high, then you might want to make sure you don't use the "heat water" function, otherwise the fuse will blow again.
Please let us know if this helps, it will benefit others in your situation.
Jan 03, 2018 | Hotpoint 23 in. BF41 Built-in Dishwasher
When my hotpoint wma 48 is on a wash cycle water starts seaping through the front door. Gets worse when it goes on to the spin cycle. Please help
Clean the door itself and the door seal. close the door and give the glass bowl a tap at the bottom where it meets the seal with your fist this should do it.If not change the door seal
Jun 11, 2010 | Hotpoint WMA48 Front Load Washer
Hotpoint wma22 is leaking between seal and door
It could be an over filling issue, or there may be a tear in the seal where you can't see it very well Take a look at my articles:
http://www.fixya.com/support/t1667828-water_spewing_out_air_vent_back_washer
Which discusses pressure switches, or
http://www.fixya.com/support/t1543617-door_seal
if you discover you do need to replace the door seal
Mar 01, 2009 | Hotpoint First Edition WMA22 Front Load...
BF41 Dishwasher with a leak stuck in mid cycle
Your air gap is clogged, the thing sticking up from the sink next to the faucet. there is a hose that goes from the air gap to the dishwasher, somewhere in that system is clogged. You can clear it if you have a quarter inch drain snake.
Apr 26, 2017 | Kenmore 17439 Built-in Dishwasher
Hotpoint WD62 leaks heavily during spin cycle
hiya m8 check the door seal first you'll need to pull the seal slightly out to see under the flappy part they usually go there this will be the most likest leak u don't have to undue anything to do any of this and when u find the hole it will only be around £15 to get a new door seal u might have to run your fingers around under the flap to find it aswell m8 let me know if it is and ill tell u how to replace it m8
May 25, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Dishwasher
Let the suds die down then pour in about 1/4 cup of vegetable oil. Start the machine and let it run a few minutes then open the door and see if it is still sudsing. This will usually kill the suds. Some times I have to repeat again but not usually. Drain the water out and run through a short cycle with regular detergent and you should be good to go again.
Mike
Jan 07, 2008 | Hotpoint 23 in. BF41 Built-in Dishwasher
DOOR WILL NOT LOCK
assuming that you didfi not unwire ther door lock, the problem is probably just that the door seal just needs bedding in and you should be able to start by closing more firmly and pushing in till the door lock catches. did you properly seat the door boot on the cabinet?
Apr 07, 2007 | Hotpoint WMA46 Front Load Washer
Top basket spray not working
did you solve this problem mine is doing the same?
Aug 20, 2006 | Hotpoint 23 in. BF41 Built-in Dishwasher
Dishwashers Logo
83 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
