Question about Nintendo Wii Console
What is the weight limit on the wii fit balance board
  • jdw316 Dec 21, 2008
    What do you mean by us normal people? Are you saying other people are not normal if you think you are then something is wrong with your racist self.
  • 84 Answers
The WII fit board can hold up to 300 pounds
to us normal people 136Kg or 22 stone
pls rate.
Posted on Dec 17, 2008
  • Jordan Moss
    Jordan Moss Dec 25, 2008
    Are you serious ?!
    "to us normal people" was refering to the fact NORMAL PEOPLE DON'T MEASURE IN IMPERIAL UNITS ANYMORE
    "Rasist" maybe you should check up that word before using it
    And also check up the word Prejudice Because by giving me a a bad mark for a good answer and calling ME racist i think you should consider being NORMAL
Wii board does not show correct weight, sometimes im a stone heavier or half a stone lighter my actual weight
The Wii balance board isn't known for being hugely accurate, I wouldn't pay too much attention to what it says your weight is.
May 10, 2011 | Nintendo Wii Fit for Wii
After not using it for a few months the balance board doesnt meaure weight or balance properly
HI there.
You need to re seat the sensors.
I have written a great tip with video. You can find it here.
Thank you
Dec 01, 2010 | Nintendo Wii Fit - Balance Board + Game...
The board thinks there is weight on it when there
If you have tried turning the wii and balance board off and then on again (sometimes board can get confused when initializing), you may need to contact Nintendo for repair/replacement. If the board is new, try bringing it back to the store.
May 02, 2010 | Nintendo Wii Fit - Balance Board + Game...
Wii balance board weight differently after put on a wii board sk
Sometimes the silicone skin can have an effect on the Wii Fit Balance Board if it gets pinched. Make sure that it is not interfering with the the total movement of the top portion of the Wii Fit balance board and the space between the top and the middle of the unit. If there is any obstruction, refit the skin on the balance board.
Feb 26, 2009 | Nintendo Wii Fit for Wii
Jillian Michaels won't allow Wii Balance Board for weigh in
Actually, I had the same problem and discovered that you have to have the wii remote in your hand and that you must push the A button once you're on the board. Otherwise it just keeps telling you that you're moving too much.
Feb 08, 2009 | Majesco Jillian Michaels Fitness Ultimatum...
Want to use two wii fit boards at the same time?
You can't sync 2 balance boards to one wii.
I heard this is why but this isnt confirmed...
the wii can only register 4 controllers at one time... the wiifit balance board counts as 2 controllers, leaving only 2 controllers available... obviously a person would want at least one regular controller to use along with the wiifit balance board, so just using wiifit leaves only one free controller slot available...
hope this helps...
Feb 05, 2009 | Nintendo Wii Fit for Wii
Wii Fit instructions for movements are all in reverse
No it is not how Wii Fit is supposed to be. First, let me suggest that you ensure that the power button on the Wii Fit Balance Board is facing AWAY from the TV set. This may seem silly, but it's the most common error. As for the Hula Hoop game, make sure that your weight is all on the side of the Wii Fit Balance Board in the direction that you need to lean to catch the hoop.
There have been instances of the sensors in the Wii Fit Balance Board going out. If you have tried the above steps and you are still getting errors, please go to www.nintendo.com, register your product, and open a problem ticket with them.
Jan 28, 2009 | Nintendo Video Game Consoles & Games
Wii Fit Balance Board Won't turn on
i fixed it by re-syncing it with the console. all good now, although it seems a little out of balance, but at least working....
Jan 04, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test.
Please be a bit more detailed in the problem. The Wii Fit Balance Board is very sensitive to weight shifts. Ensure that you allow the board to calibrate properly. To do this, I would suggest the following steps:
1) Place balance board on a sturdy, flat, smooth surface. If you have average-shag carpet, be sure to use the little adapters that fit over the feet. If the carpet is too thick, then it will NOT work properly. You may want to consider a small piece of plywood or something similar to set between the carpet and Balance Board.
2) Don't step onto the board until it has calibrated (this is when the board establishes its zero point). It will clearly say "Starting Up" followed by "Ok, Step On." After this, you can generally stay on the board unless a particular routine asks you to get off or for some reason it needs to recalibrate.
3) Finally, you must ALWAYS back out all the way to the Wii Fit Plaza (where you pick your Mii) if you change players. Once the board is configured for one player, it will only be suitable for that individual. Its sensitivity is based on an individuals weight. For instance, if the board is calibrated for a 3-year old's Mii, and an adult decides to play any of the routines on that Mii, the board will be over sensitive (calibrated for the lighter weight). Conversely, if an sdult's Mii is selected and a child plays a routine, the board may not detect the movement.
I hope these steps will help. If not, please offer a step by step explanation on what you are doing and I will try to reassess your situation.
Thanks!
Dec 29, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
50 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
