Question about Tomtom ONE GPS Receiver
HAVE NO LIGHTER THAT WILL ACCEPT NEW PLUGS
My 89 Ford will not accept the plug in my lighter holder - and I cannot even determine if the lighter works at all.
How long can I go on the battery? Any alternatives? Will my laptop charge it as well? Will my tomtom work without the lighter charge?
I am an old lady that loves new toys and I want a relationsip with my tomtom?
Please?
    Problem Solver:
  • 6 Answers
There are ways u can charge your gps 1 is to buy extension for your lighter i know that the plug is very big adapter is about 6.00 to 15.00 dollars.
also battery life after full charge is about 45 min not long at all
your lap to will charge it
ha hope u and your tom tom are very happy
ps keep it pro k bye bye get it
Posted on Dec 18, 2008
When I use the cigarette lighter to charge my cellphone, the battery actually DIScharges in the phone. Can this be due to reverse polarity at the lighter outlet?
no, if it was it would blow a fuse when phone is plugged up. maybe a bad charger . can you try it in differe..nt vechile to see if it does same thing
Jan 02, 2011 | Ford F-450 Cars & Trucks
How can I get my cigarette light plugs to work. There is no mention in manual except for the rear plug?
I believe the first step is to be sure what the problem actually is by attaching your test light clip to ground and poking the pointy end at the center in the bottom of the socket where the lighter element plugs in. While the key is on you should have power and the test light will light up. If it doesn't light up use your test light to check the fuses, if you find any broken fuses replace them and check the lighter again. On my '89 camry the lighter didn't work and I had to remove the radio to find that the wire that goes to the back of the lighter had come disconnected. In your case I suspect that you will solve the problem by purchasing a new lighter element and/or replacing the fuse because it is very seldom that anything else goes wrong with the cig lighter.
Best regards.
Oct 28, 2010 | 2002 Suzuki XL-7
Replacement of cigarette lighter
Best regards.
Oct 28, 2010 | 2000 Toyota Camry
Is the cigarette lighter also the plug for cell phone charger?
The cigarette lighter plug should also work for the phone charger as long as the phone charger uses the cigarette lighter style plug(long with two metal contacts on the sides and a button contact on the tip). Most standard car chargers will fit both cigarette and auxillary style plugs.
Dec 29, 2009 | 2004 Ford Focus
Garmin screen is all i get, then it turns off
try changing the batteries or placing the device on charge and unplugging it, if both those don't work go to the support section on garmin's website www.garmin.com/support/
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
More cigarette lighter plugs
Yes. Recommend to have local repair/stereo shop perform installation due to running new wiring and fusing circuits.
Mar 29, 2009 | 2004 Ford Explorer Sport Trac
LIGHTER FOR MY SATURN
Probably would have been a good idea to purchase a LED 12vdc tester while at the auto parts store. If the original holder is in the vehicle and the fuse was checked. The next thing you need to do is take the 12vdc tester and touch one lead to the side of the holder and look inside and see a center contact at the bottom of the holder, touch the other lead from the tester to that contact. If your light turns on then you actually have power there. If not the fuse to the lighter is out. You can not visually check a fuse, they must be tested. If you have power try to plug in another lighter. If you have to change or add a new holder the center wire is power and the ring or frame is negative. Depending where the lighter is located I have found coins, gum wrappers etc. in the holder you may also want to make sure nothing is in the holder.
Oct 17, 2008 | JVC KD-G230 CD Player
Tomtom ONE GPS Receiver Logo
47 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
