Question about Jensen VM9510 Car DVD Player
UV7I Volume Control Problem
Everytime the car is shut off and turned back on the volume automatically resets to 27. Having to turn the volume down everytime i start the vehicle is getting old. Is there any way to reset the default volume?
  • robert_helfe Dec 21, 2008
    Nevermind everyone, i figured it out!!!! =) Make sure the screen is not out (looking like normal cd player) adjust the volume where you want it to be when you start the car, press and hold in the volume knob until you hear 2 consecutive beeps. That's it!
  • alienship200 Mar 23, 2009
    I have the same problem and set the turn on volume but how do I get it back to the setting where it rembers the volume setting it was on when the car or unit is shut off and back on. I tried the reset but it changes nothing with the start volume I set it at.
  • 3 Answers
They all do that ive tried you just have to deal with it it sucks but life goes on wright wright
Posted on Dec 20, 2008
I have a 2008 hyundai elantra...when listening to the radio or cd it sounds like someone is messing with the volume, turning it up and down.
If the issue you are describing follows this pattern (when slowing down, the radio turns down in volume, and when speeding up it turns up in volume), then your vehicle is equiped with an automatic volume control. This function was to allow the operator not to have to touch the volume control while driving. The volume increases to compensate for road noise. You should have a function control button that will allow you to turn this function off. Hope this helps.
Aug 20, 2011 | Car Audio & Video
When I turn the knob to increase the volume, it goes up to three and drops back down to zero. It does this everytime I move the knob at a normal pace or faster. However, if I push the knob slightly in and...
It could be a safety protection meaning you could have a shorted speaker check all speakers and wiring, or it could be a defective volume control, try cleaning the volume with a contact cleaner spray you can find at any good electronic store (you normally have to open the radio to reach the POTENTIOMETER/VOLUME) to be able to spray inside it, than alternate (high/low) the control repetively to move/clean the volume's circuitry
Feb 09, 2011 | Car Audio & Video
The problem started initially with the remote control not working. When I turn the TV on at the control panel the volume is all the way up. When I turn it down and let go of the volume button it...
Check the volume up button. It is either just stuck or defective, causing a constant stream of data to be sent to the microprocessor. You remote isn't recognized because the data line is continuously active.
Aug 31, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
Turn deck on volume at 31 why?
In the settings, you should have a start up volume.
just change this to what ever volume you would like it to start up on.
Feb 22, 2009 | Jensen VM9410 Car DVD Player
ViewSonic N2750w 27 in Volume turns down by itself tv can be on for a couple of minutes then turns down completely try to turn the volume up with the remote. will turn back down
Could be a problem with the down volume button on the tv. the board it's on ir its harness. Check them all. Make sure the volume buttons plastic actuator moves freely and is not stuck.
If these parts are all good, you have a problem on the main board. You may have to trace the control lines as far as you can and check any capacitors along the way. If you have an oscilliscope you can test the lines to see if the up volume is working correctly. If there is noise on it, you might find a bad capacitor if you can trace it back far enough. Schematic helps here.
Of course, make sure nothing is shining on the sensor window on the TV. You might want to scope that line as well (IR sensor line).
If none of that helps, get hold of Viewsonic and find your closest service provider. You can order a main board from them.
Of course, you could try just using the audio out jacks to an amplifier or a surround sound amplifer. Then you would use the remotecontrol for the surround sound system to control your volume.
Bet you were going to buy one anyway right?
Dec 27, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Volume control problem
Ok my head unit is stuck on 10 with my valume and it wont change how can I fix that
Nov 25, 2007 | Dual XDVD8181 Car Video Player
Volume control stopped working
Take the warranty and the MP3 and go to the shop from where you bought. They will repair for you.
Sep 02, 2007 | SanDisk Sansa m240 MP3 Player
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
Jensen VM9510 Car DVD Player Logo
281 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
