The engine was seized and so we removed the pump and is still wouldn't budge. Once inside we found that the piston is fine and that the crankshaft is seized in place and we can't figure out how to get it out. The flywheel is removed, but the oil seal is still in place along with the crankshaft. Instructions on how to remove with out damaging anything would be most helpful and appreciated!
SOURCE: Can't fine where to put pump oil in
Dear glenoaks06,
I handled various Karcher washers, but the 2500 I never came across it. Just the same I will give you a few hints and maybe the solution for the problem. When the oil is milkey this means it has water in it. This means that there are faulty seals for sure. Now in many Power Washers the compartment where the oil is located is filled with oil prior to assembling the head unit that contains the pistons. So you have to take apart the the complete head change all seals( HP seals, LP seals and OIL seals). There are pumps that take multi-grade oil(15/50) and others 90 grade oil. If your pump is fan cooled, it probably takes 15/50 oil. Now one of the main biggest problem of water in oil is Faulty and Scratched PISTONS.
So when you have the pump apart....check condition of pistons. It is useless to change seals if pistons are damaged.
Now one thing regarding your problem, is that you have to put together the head with the pump upside down, so that you can fill the compartment (where the pistons are pushed by the swash plate), with OIL, before you put back the complete head with good pistons,springs,seals, valves...etc..etc. These few hints are relevant to quite a number of Karcher washers.
Regards,
Fulltech.
SOURCE: pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
