Philip 50 inch plasma-red dots
I have a Philips plasma 50 inch tv, I had the red dot problem a year ago. Went through the extended warranty and Andulusia TV service in Bensalem, to repair the problem. They had it for amonth and told me that they replaced the motherboard, it wasn't fixed. I called them and they came out again and took my TV for 2 weeks. They called and said it was fixed and they are going to deliver my TV back to me. Put the TV on and 2 hours later, BAM ! red dots again. Called the warranty company (Repair Master) and asked them what do I have to do to get it fixed or get it replaced, obviously something is wrong with it. They told me to send it back to Andulusia TV and it will not be replaced until they say it can't be repaired. Andulusia wants me to give them the TV back again. I said, No, you had it two times already in a year and its not fixed. Basically, they told me to go pound sand. I think the system is that they wait you out until the warranty is over, then it's screw you. I'm Hot. This TV was $3,800.00 and $500.00 for the warranty. I need some good adavice. Can you help me out?
    Top Expert:
  • Televison & ... Master
  • 75,774 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Mar 05, 2017
SOURCE: Zenith 50 plasma
plasma parts are currently alot on backorder, so it will take time to get them.is your repairguy ASC for LGE?? if not, take your TV to an ASC. they get the training and know what they are doing,not those wannabe repairman........
Posted on Jan 11, 2008
  • 4 Answers
SOURCE: Sound on TV
I to have a sound problem with the W3201''
I too have a sound problem witn the W3201C 32 inc LCD TV. My set is a mere 2 years old. the sound pulses when turned on, however after about 20 mins or so wih the sound muted, the sound does clear up - how long this fix will work is anybodies guess and when that fix goes, what then. I have phoned Dell and they told me they no longer make either this TV or the parts to repair it. I REALLY dont think we should silently put up with this
shoddy workmanship, If Dell refuses to replace these defective TV's, which were certainly not cheap - I for one am seeking legal counsel
c
Posted on Sep 13, 2008
  • 179 Answers
SOURCE: I have a Philips plasma
the panel is bas. it has a diffusion problem.most extended warranty companies require you to let the shop try 3 times to repair for the same problem. on the 4th time they talk replacement.
best to read the contract.
Posted on Dec 18, 2008
SOURCE: I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV i
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Tyler
Posted on May 16, 2009
  • 10 Answers
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
50HP66 50 in. Plasma Television: i have red dots/shadowing on my tv...
I got the red dots really bad on my toshiba 50hp66 after an hour or two of watching tv. I found out that if you open up the tv in the back on the left you will find two adjustment pots labelled Vsc and Vy. I took a sharpie and marked where the factory defaults were first. Then I adjusted the Vy pot down a little bit and the red spots were gone! My tv looks great again!
May 16, 2010 | Toshiba 50HP66 50 in. Plasma Television
I have a Philips plasma 50 inch tv, I had the red dot problem a year ago. Went through the extended warranty and Andulusia TV service in Bensalem, to repair the problem. They had it for amonth and told me...
Dec 17, 2008 | Televison & Video
Red dots
We had same problem with our Samsung last year. When my husband called, they knew immediately with the problem was and sent someone out to replace the main board. If we hadn't been under warrantly, it would have cost a fortune.
Aug 15, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Red dots on a black background
Try to adjust the Vs down about 5-10V.
Jan 05, 2008 | LG 42PC1DA 42 in. Plasma HDTV
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
60 inch phillips plasma
is this a philips or a samsung? either way it sound like a diffusion problem..have the v_set and the v_scan voltages set lower bu 15vdc
if this wont help it is time for a panel
Nov 07, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Dec 17, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Little red dots
The driver board is going bad it sounds like and if you do not call up and get it fixed under warranty, as it should still be under a warranty, then its going to be a nice hefty repair bill. Good Luck Ps Please dont forget to rate this thread
Oct 19, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
