Question about Whirlpool RBS305PDS Electric Single Oven
Oven does not work after running self cleaning
I have a Whirlpool oven model RBS305PDQ6. After running self clean the oven no longer heats up. The control panel still functions fully, says it is preheating when bake and start are selected, you can adjust the temperature, but the elements do not work. The fan blows, there is air coming out of the front vent. Everything appears normal, just will not heat up, neither bake nor broil.
  • 4 more comments
  • Rudy F Dec 21, 2008
    Having same issue. How do I reset the element?
  • Anonymous Dec 28, 2008
    same problem...
  • ohea2 Dec 29, 2008
    I have the same problem. Any idea how to solve this
  • nelm Dec 31, 2008
    It's nice to list the possible solutions; but without the steps to do them, they are useless. How do you (for instatnce) reset the element, test the element, or test the connectors. Can you explain what the element is and how you go about testing it. Maybe a connection to a manual would help and a suggested page.
  • nelm Dec 31, 2008
    It's nice to list the possible solutions; but without the steps to do them, they are useless. How do you (for instatnce) set the element, test the element, or test the connection. What is an element and how do you test it. Could you include some steps and explanations. Maybe you can give a link to a manual where you can referrence a page that would help.
    I have already locked and unlocked it a number of times. Just like dupe1955, everything works except for heat.
  • Anonymous Jan 01, 2009
    same prob.. let us know of any solution found or as stated, steps to perform tests/solution.. thanks
    Scholar:
  • 33 Answers
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
    I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
    Nov 26, 2014 | Whirlpool Ovens
    My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
    Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
    Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
    Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
    Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
    Jan 19, 2011 | Whirlpool Ovens
    I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
    Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
    Aug 16, 2010 | Whirlpool Ovens
    After doing a self clean on a whirlpool oven model rbs245pd06 it will no longer heat on bake or broil.
    Unfortunately you have found out the hard way about the self cleaning feature... they cause many problems...
    Here is a tip that I wrote about that and it includes some things you can try to get you oven to unlock...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Mar 30, 2010 | Ovens
    After using self cleaning function my oven had no power. Replaced the thermal relay and it worked fine. Now, we have run the self cleaning function once more and the oven died again. Is there another...
    There is always going to be a problem whe you run your self clean feature. Your oven heats to over 800 degrees and this high heat takes out electronic parts.
    Oct 18, 2009 | Whirlpool RBS245PDS Electric Single Oven
    Whirlpool electric double oven #RBD305PDQ14 control panel blank
    I suspect a poor connection at the wiring to the EOC is the cause of the failures.
    Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
    Self cleaning oven won't start self clean mode
    NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
    Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
    Whirlpool RBS305PDS Electric Single Oven Logo
    555 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal De
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
